The Map Suite Android Edition illustrated QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This edition of the QuickStart Guide supports Android Edition 10.0.0 and higher, and will show you how to create an Android application using Map Suite Android Edition.
If you want to build an iOS application using the standard Map Suite iOS Edition product, please see the iOS QuickStart Guide instead.
Please follow our Android Edition Installation Guide for Xamarin Android development environment.
Let's start by creating a new Android project in Microsoft Visual Studio (2012 or newer) named HelloWorld (see Figure 1). We can create the project with .NET Framework 4.5.
The project HelloWorld is created in a new solution called HelloWorld. The wizard creates a single Android Application. Choose Android version (4.0.3 or higher) for the project:
Now we are going to install MapSuite Mobile for iOS NuGet package. Let's open NuGet Manager dialog and install following three NuGet packages.
Figure 2. Open NuGet Manager UI in the Visual Studio IDE.
Figure 3. Install Android Package.
Figure 4. Install Shapefile Package.
Create a new folder under sdcard named “Android Sample”.
One is under our application, like “/data/data/HelloWorld.HelloWorld/AppData/”.
protected override void OnCreate(Bundle bundle) { base.OnCreate(bundle); SetContentView(Resource.Layout.Main); // Copy the required Shapefiles to Device. string targetDirectory = (@"/mnt/sdcard/Android.Sample/GetStarted/"); CopySampleData(targetDirectory); }
This method will copy data to the target path, if the folder does not exist.
private void CopySampleData(string targetDirectory) { if (!Directory.Exists(targetDirectory)) { Directory.CreateDirectory(targetDirectory); foreach (string filename in Assets.List("AppData")) { Stream stream = Assets.Open("AppData/" + filename); FileStream fileStream = File.Create(Path.Combine(targetDirectory, filename)); stream.CopyTo(fileStream); fileStream.Close(); stream.Close(); } } }
We are going to add more project
Note: Although it is not a ThinkGeo assembly, you also need to add “System.Windows.dll ” to the references. System.Windows can be found on the .NET tab of the Add Reference dialog. If you don't do this, you will get the following error when you compile the project:“The type 'System.Collections.Specialized.INotifyCollectionChanged' is defined in an assembly that is not referenced. You must add a reference to assembly 'System.Windows, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes'.”
<?xml version="1.0" encoding="utf-8"?> <LinearLayout xmlns:android="http://schemas.android.com/apk/res/android" android:orientation="vertical" android:layout_width="fill_parent" android:layout_height="fill_parent"> <ThinkGeo.MapSuite.Android.MapView android:id="@+id/MapView" android:layout_width="fill_parent" android:layout_height="fill_parent"/> </LinearLayout>
Now we have our “AndroidEdition.dll” and “MapSuitePortableCore.dll” referenced and a MapView added.
The first step in creating our “Hello World” sample application is to set references to the ThinkGeo.MapSuite, ThinkGeo.MapSuite.Android and ThinkGeo.MapSuite.Shapes namespaces at the very top of our code, since we'll use many classes within them. Set the reference like this:
using ThinkGeo.MapSuite; using ThinkGeo.MapSuite.Android; using ThinkGeo.MapSuite.Shapes;
Now the project is ready, Map Suite Runtime license is required for running and debugging your product. Please open the Product Center, then generate your license by steps like login account → activate or start evaluation → continue debugging → get runtime license. For more details, please refer to (http://wiki.thinkgeo.com/wiki/map_suite_runtime_license_guide_for_mobile).
Now, Let's add a base overlay to display the world map witch called “WorldStreetsAndImageryOverlay”.
protected override void OnCreate(Bundle bundle) { base.OnCreate(bundle); SetContentView(Resource.Layout.Main); // Get MapView From Activity's View. MapView mapView = FindViewById<MapView>(Resource.Id.MapView); // Set the Map Unit to DecimalDegrees, the Shapefile’s unit of measure. mapView.MapUnit = GeographyUnit.DecimalDegree; // Create a WorldStreetsAndImageryOverlay. WorldStreetsAndImageryOverlay worldStreetsAndImageryOverlay = new WorldStreetsAndImageryOverlay(); // Add a WorldStreetsAndImageryOverlay . mapView.Overlays.Add("WorldStreetsAndImageryOverlay", worldStreetsAndImageryOverlay); // Set a proper extent for the map. The extent is the geographical area you want it to display. mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26); }
Our next step is to define and add our layers. All of our sample code is placed in the OnCreate method of the MainActivity.cs. So our MapView can load and render the data, we can add logic to check the data to avoid coping it every time.
protected override void OnCreate(Bundle bundle) { base.OnCreate(bundle); SetContentView(Resource.Layout.Main); // Copy the required shapefiles to Device. string targetDirectory = (@"/mnt/sdcard/Android.Sample/GetStarted/"); CopySampleData(targetDirectory); MapView mapView = FindViewById<MapView>(Resource.Id.MapView); mapView.MapUnit = GeographyUnit.DecimalDegree; // Create a WorldStreetsAndImageryOverlay. WorldStreetsAndImageryOverlay worldStreetsAndImageryOverlay = new WorldStreetsAndImageryOverlay(); // Add a WorldStreetsAndImageryOverlay . mapView.Overlays.Add("WorldStreetsAndImageryOverlay", worldStreetsAndImageryOverlay); // We create a new Layer and pass the path to a Shapefile into its constructor. ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "cntry02.shp")); // Set the worldLayer with a preset Style, as AreaStyles.Country1 has a YellowGreen background and black border, our worldLayer will have the same render style. worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1; // This setting will apply from ZoomLevel01 to ZoomLevel20, which means the map will be rendered with the same style no matter how far we zoom in or out. worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We need to create a LayerOverlayer to add the world layer. LayerOverlay overlay = new LayerOverlay(); overlay.Opacity = 0.8; overlay.Layers.Add(worldLayer); mapView.Overlays.Add("Countries02", overlay); mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26); }
Figure 4. A simple map of Europe.
protected override void OnCreate(Bundle bundle) { base.OnCreate(bundle); SetContentView(Resource.Layout.Main); string targetDirectory = (@"/mnt/sdcard/Android.Sample/GetStarted/"); CopySampleData(targetDirectory); MapView mapView = FindViewById<MapView>(Resource.Id.MapView); mapView.MapUnit = GeographyUnit.DecimalDegree; // Create a WorldStreetsAndImageryOverlay. WorldStreetsAndImageryOverlay worldStreetsAndImageryOverlay = new WorldStreetsAndImageryOverlay(); // Add a WorldStreetsAndImageryOverlay . mapView.Overlays.Add("WorldStreetsAndImageryOverlay", worldStreetsAndImageryOverlay); ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "cntry02.shp")); worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1; worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // Similarly, we use the presetPointStyle for cities. ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "capital.shp")); // These settings will apply from ZoomLevel01 to ZoomLevel20, which means city symbols will be rendered in the same style, no matter how far we zoom in or out. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital3; // We need to add both of the new layers to the Map's Static Overlay. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We need to create a LayerOverlayer to add the world layer. LayerOverlay overlay = new LayerOverlay(); overlay.Opacity = 0.8; overlay.Layers.Add(worldLayer); overlay.Layers.Add(capitalLayer); mapView.Overlays.Add("Countries02", overlay); mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26); }
protected override void OnCreate(Bundle bundle) { base.OnCreate(bundle); SetContentView(Resource.Layout.Main); string targetDirectory = (@"/mnt/sdcard/Android.Sample/GetStarted/"); CopySampleData(targetDirectory); MapView mapView = FindViewById<MapView>(Resource.Id.MapView); mapView.MapUnit = GeographyUnit.DecimalDegree; WorldStreetsAndImageryOverlay worldStreetsAndImageryOverlay = new WorldStreetsAndImageryOverlay(); mapView.Overlays.Add("WorldStreetsAndImageryOverlay", worldStreetsAndImageryOverlay); ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "cntry02.shp")); worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1; worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "capital.shp")); capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital3; capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We create a new Layer for labeling the capitals. ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "capital.shp")); // We use the preset TextStyle. Here we pass in the “CITY_NAME”, the name of the field containing the values we want to label the map with. capitalLabelLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.Capital3("CITY_NAME"); capitalLabelLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // As the map is drawn by tiles, it needs to draw on the margin to make sure the text is complete after joining the tiles together. // Change the number below (to 0, for example) to better understand how this works. capitalLabelLayer.DrawingMarginPercentage = 50; LayerOverlay overlay = new LayerOverlay(); overlay.Opacity = 0.8; overlay.Layers.Add(worldLayer); overlay.Layers.Add(capitalLayer); // Add the label layer to LayerOverlay. overlay.Layers.Add(capitalLabelLayer); mapView.Overlays.Add("Countries02", overlay); mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26); }
protected override void OnCreate(Bundle bundle) { base.OnCreate(bundle); SetContentView(Resource.Layout.Main); string targetDirectory = (@"/mnt/sdcard/Android.Sample/GetStarted/"); CopySampleData(targetDirectory); MapView mapView = FindViewById<MapView>(Resource.Id.MapView); mapView.MapUnit = GeographyUnit.DecimalDegree; WorldStreetsAndImageryOverlay worldStreetsAndImageryOverlay = new WorldStreetsAndImageryOverlay(); mapView.Overlays.Add("WorldStreetsAndImageryOverlay", worldStreetsAndImageryOverlay); ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "cntry02.shp")); worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.Country1; worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "capital.shp")); // We can customize our own Style. Here we pass in a color and size. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.White, 7, GeoColor.StandardColors.Brown); // The Style we set here is available from ZoomLevel01 to ZoomLevel05. That means if we zoom in a bit more, it will no longer be visible. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05; capitalLayer.ZoomLevelSet.ZoomLevel06.DefaultPointStyle = PointStyles.Capital3; // The Style we set here is available from ZoomLevel06 to ZoomLevel20. That means if we zoom out a bit more, it will no longer be visible. capitalLayer.ZoomLevelSet.ZoomLevel06.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "capital.shp")); // We can customize our own TextStyle. Here we pass in the font, size, style and color. capitalLabelLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.CreateSimpleTextStyle("CITY_NAME", "Arial", 8, DrawingFontStyles.Italic, GeoColor.StandardColors.Black, 3, 3); // The TextStyle we set here is available from ZoomLevel01 to ZoomLevel05. capitalLabelLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05; capitalLabelLayer.ZoomLevelSet.ZoomLevel06.DefaultTextStyle = TextStyles.Capital3("CITY_NAME"); // The TextStyle we set here is available from ZoomLevel06 to ZoomLevel20. capitalLabelLayer.ZoomLevelSet.ZoomLevel06.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; capitalLabelLayer.DrawingMarginPercentage = 50; LayerOverlay overlay = new LayerOverlay(); overlay.Opacity = 0.8; overlay.Layers.Add(worldLayer); overlay.Layers.Add(capitalLayer); // Add the label layer to LayerOverlay. overlay.Layers.Add(capitalLabelLayer); mapView.Overlays.Add("Countries02", overlay); mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26); }
