map_suite_mobile_for_android_features_bug_fixes_change_log
Map Suite Mobile For Android Features & Bug Fixes Change Log
Version 10.2.0.0
Release date: 10/27/2017
ThinkGeo.MapSuite.Android Namespace:
  • Enhanced “draw()” of BuildingTile class, remove the clear paint
  • Fixed a bug where BingMapsOverlay has offset in certain scenarios
ThinkGeo.MapSuite Namespace:
Version 10.1.0.0
Release date: 06/21/2017
  • Added MapResizeMode property for android map control support
Version 10.0.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Fixed a bug that the MapView's scale is not limited by MinimumScale and MaximumScale.
  • Added rotation support for CompassMapTool.
  • Fixed a but that CompassMapTool is not loaded correctly.
  • Added custom font support for TextStyle.
  • Fixed WorldMapKit overlay Uri format issue.
  • Fixed a bug on dash style.
  • Fixed the hardcode “Format” parameter in WmsOverlay.
  • Fixed the bug that the BoundingBoxUnit nor TileMatrix cannot be changed on TileCache.
  • Fixed an OutOfMemory issue for OpenStreetMapOverlay.
  • Fixed a bug that makes the app crashes occasionally for OpenStreetMapOverlay.
  • Fixed a bug that makes the app crashes occasionally for GoogleMapsOverlay.
  • Added loading font from external storage support for TextStyle.
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.AndroidEdition Namespace:
  • Added expire interval to SqliteBitmapTileCache.
  • Added two events to allow user to load large raster for GdiPlusRasterLayer without OOM issue.
  • Added supports to allow user to switch tile size between 256 * 256 and 512 * 512.
  • Added more logic to filter Google unexpected result return from server.
  • Added FeatureSourceMarkerOverlay support.
  • Added MapBoxTileOverlay support.
  • Fixed a bug where the out of memory exception during drawing TileOverlays.
  • Fixed a bug where the map zooms in/out to an unexpected area.
  • Fixed a bug where the null reference of the Context object.
  • Added Leader Lines.
map_suite_mobile_for_android_features_bug_fixes_change_log.1509437072.txt.gz · Last modified: 2017/10/31 08:04 by tgwikiupdate
