map_suite_ios_edition_features_bug_fixes_change_log
Map Suite iOS Edition Features & Bug Fixes Change Log
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.iOSEdition Namespace:
  • Fixed a bug where there are something wrong with the map events when it is not full screen.
  • Added RestrictExtent and max/min scales range limits.
  • Added support of requesting tiles image from MapBox services.
  • Fixed a bug where the OperationQueue throws exception after transferring to Unified API.
  • Fixed a bug where the continuously panning doesn't stop the previous panning animation.
  • Fixed a bug where drawing raster files to an unexpected area.
  • Supported Unified API to allow user to build 64bit apps.
  • Added the new API SetWellKnownBinary(bytemap_suite_ios_edition_features_bug_fixes_change_log wkb) to Feature class to allow changing the WKB of the feature.
  • Improved the performance of method bytemap_suite_ios_edition_features_bug_fixes_change_log ShapeFile.ReadPolygon(bytemap_suite_ios_edition_features_bug_fixes_change_log dataBytes, int startIndex).
  • Added Leader Lines.
map_suite_ios_edition_features_bug_fixes_change_log.1442287100.txt.gz · Last modified: 2015/09/15 03:18 by admin
