map_suite_gis_editor_data_repository_plugin_samples
Map_Suite_GIS_Editor_Data_Repository_Plugin_Samples
Zoom To A Point
Screenshot width=78Sample width=66Product Description
wiki View Source
C# Download
Need it in another language?
Services \\ \\ Applies To: GIS Editor \\ This sample will show you how to create a UI plugin which uses the menu bar, map and has settings. In the sample we will add a button to the menu bar which when clicked will popup a dialog allow you to enter in X & Y coordinated. When you are finished the map will zoom to that location based on a zoom level that you set in its settings. We will create a setting control to hold the setting and persist it in the plugin between instantiations.
map_suite_gis_editor_data_repository_plugin_samples.1440040123.txt.gz · Last modified: 2015/09/16 03:46 (external edit)
