| Screenshot | width=78 | Sample | width=66 | Products | Description |
| C# Download VB Download | Geocoder, Web | The Map Suite Geocoder “How Do I?” solution offers a series of useful how-to examples for using the Map Suite Geocoder component. The bundled solution comes with a small set of sample data from Chicago, IL and demonstrates geocoding, reverse geocoding, batch geocoding, use of fuzzy matching logic, getting the closest street number to a point, and much more. Full source code is included in both C# and VB.NET languages; simply select your preferred language to download the associated solution. Please note that you will need an evaluation (or full version) of both Map Suite Geocoder and Map Suite Web Edition to build and run these samples. |
