map_suite_desktop_for_winforms_installation_guide
Map Suite Desktop for WinForms Installation Guide
System Requirements
  • Microsoft Windows 7 or newer, or Microsoft Windows Server 2012 or newer
  • Visual Studio or Visual Studio Express, 2010 or newer
  • C#, Visual Basic .NET, and other .NET-compatible languages are supported for development
  • For Map Suite MVC Edition:
    • ASP.NET MVC 4, ASP.NET MVC 5
    • Traditional ASPX or Razor ViewEngine
Environment Preparation
Install .NET Framework 4.0
Map Suite requires the Microsoft .NET Framework 4.0 or newer.
Install Visual Studio 2010 Tools
Map Suite Product Additional Tools Needed
Map Suite MVC Edition ASP.NET MVC 4 for Visual Studio 2010 SP1
Begin Your Development
Setup Mono runtime and MonoDevelop IDE
map_suite_desktop_for_winforms_installation_guide.1485408165.txt.gz · Last modified: 2017/01/26 05:22 by marklee
