Map Suite requires the Microsoft .NET Framework 4.0 or newer.
Map Suite Product | Additional Tools Needed |
Map Suite MVC Edition | ASP.NET MVC 4 for Visual Studio 2010 SP1 |
Prepare a clean Ubuntu environment with version 14.04 is recommended.
Press Ctrl + Alt + T to open a terminal window.
Add the Mono Project GPG signin key and the package repository to your system (if you don’t use sudo, be sure to switch to root). Please issue the following commands line by line:
```perl
sudo apt-key adv –keyserver hkp://keyserver.ubuntu.com:80 –recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
echo “deb http://download.mono-project.com/repo/debian wheezy main” | sudo tee /etc/apt/sources.list.d/mono-xamarin.list
sudo apt-get update
To Install mod_mono, we will need to add a second repository to OS, issue the following commands in terminal.
perl echo "deb http://download.mono-project.com/repo/debian wheezy-apache24-compat main" | sudo tee -a /etc/apt/sources.list.d/mono-xamarin.list
Install the mono environment. Issue the following commands line by line, depending on network this step may take a few minutes.
```perl
sudo apt-get install mono-devel
sudo apt-get install mono-complete sudo apt-get install referenceassemblies-pcl ```
Notice: Please enter Y when asked to continue. *
Install the IDE, MonoDevelop is recommend to develop on Linux. Run the following command to install Mono Develop on your computer.
perl sudo apt-get install monodevelop
Then, install the specific version of MonoDevelop that gives you a working ASP.NET add-in:
perl sudo apt-get install monodevelop=5.10.0.871-0xamarin2
To host the ASP.Net debug sample, install XSP4.
perl sudo apt-get install mono-xsp4
Run monodevelop
command in terminal to open MonoDevelop, or you can click on left top corner of task bar to search MonoDevelop and run it. You can open Visual Studio solution file via MonoDevelop.
