map_suite_desktop_for_winforms_installation_guide
Map Suite Desktop Edition Installation Guide
System Requirements
  • Microsoft Windows 7 or newer, or Microsoft Windows Server 2012 or newer
  • Visual Studio or Visual Studio Express, 2010 or newer
  • C#, Visual Basic .NET, and other .NET-compatible languages are supported for development
  • For Map Suite MVC Edition:
    • ASP.NET MVC 3, ASP.NET MVC 4, ASP.NET MVC 5
    • Traditional ASPX or Razor ViewEngine
Environment Preparation
Install .NET Framework 4.0
Map Suite requires the Microsoft .NET Framework 4.0 or newer.
If you are using Visual Studio 2010, make sure to install Visual Studio 2010 Service Pack 1.
Install Visual Studio 2010 Tools
Map Suite Product Additional Tools Needed
Map Suite MVC Edition ASP.NET MVC 4 for Visual Studio 2010 SP1
Map Suite Silverlight Edition Silverlight 4 Tools for Visual Studio 2010, or
Silverlight 5 Tools for Visual Studio 2010 SP1
Begin Your Development
Setup Mono runtime and MonoDevelop IDE
  1. Prepare a clean Ubuntu environment with version 14.04 is recommended.
  2. Press Ctrl + Alt + T to open a terminal window.
  3. Add the Mono Project GPG signin key and the package repository to your system (if you don’t use sudo, be sure to switch to root). Please issue the following commands line by line:
    ```perl
    sudo apt-key adv –keyserver hkp://keyserver.ubuntu.com:80 –recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
    echo “deb http://download.mono-project.com/repo/debian wheezy main” | sudo tee /etc/apt/sources.list.d/mono-xamarin.list
    sudo apt-get update
  4. To Install mod_mono, we will need to add a second repository to OS, issue the following commands in terminal.
    perl echo "deb http://download.mono-project.com/repo/debian wheezy-apache24-compat main" | sudo tee -a /etc/apt/sources.list.d/mono-xamarin.list
  5. Install the mono environment. Issue the following commands line by line, depending on network this step may take a few minutes.
    ```perl
    sudo apt-get install mono-devel
    sudo apt-get install mono-complete
    sudo apt-get install referenceassemblies-pcl
    Notice: Please enter Y when asked to continue. *
  6. Install the IDE, MonoDevelop is recommend to develop on Linux. Run the following command to install Mono Develop on your computer.
    perl sudo apt-get install monodevelop
  7. Then, install the specific version of MonoDevelop that gives you a working ASP.NET add-in:
    perl sudo apt-get install monodevelop=5.10.0.871-0xamarin2
  8. To host the ASP.Net debug sample, install XSP4.
    perl sudo apt-get install mono-xsp4
  9. Run monodevelop command in terminal to open MonoDevelop, or you can click on left top corner of task bar to search MonoDevelop and run it. You can open Visual Studio solution file via MonoDevelop.
map_suite_desktop_for_winforms_installation_guide.1485401727.txt.gz · Last modified: 2017/01/26 03:35 by marklee
