Map Suite requires the Microsoft .NET Framework 4.0 or newer.
If you are using Visual Studio 2010, make sure to install Visual Studio 2010 Service Pack 1.
Map Suite Product | Additional Tools Needed |
Map Suite MVC Edition | ASP.NET MVC 4 for Visual Studio 2010 SP1 |
Map Suite Silverlight Edition | Silverlight 4 Tools for Visual Studio 2010, or Silverlight 5 Tools for Visual Studio 2010 SP1 |
