Provides data for the ControlPointSelected event.
This enumeration specifies the control point type when editing a shape. The deafault value is None.
This enumeration specifies the control points connect mode when reshape a shape. The deafault value is None.
This class inherits from the InterativeOverlay abstract class. This specified overlay describes the EditShape interactive process with the MapControl using the Mouse or Keyboard.
This enumeration specifies the type of extent change that has occurred when doing interactive actions with InterativeOverlay.
This class inherits from the interactiveOverlay abstract class. This specified overlay describes the Extent Changing interactive process with the MapControl using the Mouse or Keyboard.
This class encapsulates the information and simple method for interative actions.
This class inherits from Overlay abstract class. This specified overlay describes the interative process with the MapControl using the Mouse or Keyboard.
This enumeration specifies the mode in which to draw the InterativeOverlay when doing interactive actions with InterativeOverlay.
This class specifies the InterativeResult when dealing with the Interative method in InterativeOverlay.
This class encapsulates the information and simple method for key events interative actions.
This enumeration specifies the mode used to process other overlays when doing interactive actions with InterativeOverlay.
This class inherits from the interactiveOverlay abstract class. This specified overlay describes the TrackShape interactive process with the MapControl using the Mouse or Keyborad.
This enumeration specifies the behavior that occurs when double-left-clicking on the MapControl. The default value is ZoomIn.
This enumeration specifies the behavior that occurs when double-right-clicking on the MapControl. The default value is ZoomOut.
The enumeration specifies the focus mode that will be used for map to take focus. The default value is MouseEnterFocused.
This enumeration specifies the behavior that occurs when you left-click-and-drag on the MapControl. The default value is ZoomInWithKey.
This enumeration specifies the behavior that occurs when the mouse wheel is scrolled. The default value is Zooming.
This enumeration specifies the behavior type for panning. The default value is StandardPanning.
This enumeration specifies the behavior that occurs when you right-click-and-drag on the MapControl. The default value is ZoomOutWithKey.
This enumation provides two threading options when refreshing the map. The default value is SingleThreaded.
This is the event arguments for the OverlayDrawing event on the MapEngine class. It is raised before any of the overlays are drawn.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised before any of the overlays are drawn.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the overlays are drawn.
This is the event arguments for the OverlaysDrawing event on the MapEngine class. It is raised before any of the overlays are drawn.
This is the event arguments for the OverlaysDrawn event on the MapEngine class. It is raised after the overlays are drawn.
This class is a concrete class that inherits from FileBitmapTileCache. In this class, the tiles will be marked as obsolete when you call the ClearCache method and will be deleted in a background thread.
This enumation provides the options used to set the ZoomLevel Snapping Mode. In SnapUp or Default mode, there are only 20 preset ZoomLevels whose scales are set accordingly with OpenLayers' scales. You can change this by setting the SnappingMode to None, but in doing so, you will lose the ability to use the TileCache system.
This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
This is the event arguments for the OverlayDrawing event on the MapEngine class. It is raised before the Overlay is drawn.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the Overlay has been drawn.
This class inherits from the Overlay abstract class. The specified overlay specifies the background information of the MapControl.
This class represents the event arguments for the MarkerDragged event for SimpleMarkerOverlay.
This class represents the MarkerDragging event argument for SimpleMarkerOverlay.
This class represents the base class for all classes that defines the styles applied to the markers.
This class defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
This class represents a collection of MarkerZoomLevel that determines the appearance of markers at different zoomlevels.
This class is used in WinForms Edition to access the WorldMapKit Web Map Service (WMS).
This enumeration specifies the picture formats when getting images back to client from Google Maps.
This enumeration represents which projection will use for world map kit.
This is the event arguments class for the AdornmentLayersDrawn event. It is raised after all of the AdornmentLayers have been drawn.
This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
This class is a concrete class inherits from BitmapTileCache. In this class, the tiles will be saved in memory and it provides some properties to control it very easily.
This is the base class for NativeTileCache system which inherits from TileCache class.
This class represents the parameters passed in through the CreatedMemberNode event.
This class represents the parameters passed in through the CreatingMemberObject event.
Indicates how the default value of a member will be dealt with by the modeler.
When applied to a method, specifies that the method is called after serialization of an object graph.
When applied to a method, specifies that the method is called before serialization of an object.
