map_suite_desktop_edition_vehicle_tracking_samples
Map Suite Desktop Edition Vehicle Tracking Samples
Centering And Rotating WPF
Detect GPS
Moving Vehicle with Label
Traveling Salesman Problem
In today’s project, we are seeing a variant of the sample “Traveling Salesman Problem” of the “How Do I” samples of the Routing product. At the request of a Discussion Forum user, we added a new API to the GetRouteViaVisitStops function where now you can have distinct start and end points. For being able to run this app, you will need the version 6.0.0.0 or later.
Vehicle Direction
map_suite_desktop_edition_vehicle_tracking_samples.1441695861.txt.gz · Last modified: 2015/09/08 07:04 by admin
