map_suite_desktop_edition_styles_samples
Map Suite Desktop Edition Styles Samples
Animated Gif
In today’s project, we learn how to extend InMemoryFeatureLayer to have the ability to display animated gif for each layer in the Desktop edition. You will notice that for now, we are limited to have one animated gif per InMemoryFeatureLayer but in the future, we will show the technique to have a different animated gif for each feature of the InMemoryFeatureLayer.
Default ValueStyle
Distance Line Style
EditOverlay Styles
Line Style With Increment
Multiple Dot Density Styles
Projection Distance LineStyle
Side View Icon
Smooth Transparent Route
Weather Line Style
map_suite_desktop_edition_styles_samples.1442496526.txt.gz · Last modified: 2015/09/17 13:28 by admin
