View Source |
View Source |
View Source |
This sample shows how to use the method GetFeaturesWithDistanceOf when the data is projected. We just input the unit which is projected to, do not need to mind what the real unit is for the internal data before projection. It works fine with Map Suite Assemblies 4.5.54.0 or later.
View Source |
View Source |
Applies To: Desktop \ Wpf
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinate needs to be set so that the feature get selected within a constant distance in screen coordinate to where the user clicked on regardless on the zoom level. This project will show how to accomplish that task regardless of the layer type (polygon, line or point based) and the zoom level of the current extent of the map. This is a Desktop project.
View Source |
View Source |
View Source |
Applies To: Desktop \ Web \ MVC \ Silverlight \ Services \ WPF
View Source |
From the Performance Guide:
