map_suite_desktop_edition_miscellaneous_samples
Map Suite Desktop Edition Miscellaneous Samples
Custom Scale Bar
Draw Custom Exception
Managing Cache
This project is an introduction on how to handle some basic principles of caching the map in the Desktop edition. Cache has the advantage of reusing existing images of the map when revising areas of the map that have already have been drawn. When in Snap Up mode for Zoom level snapping, cache is very handy. But it is a recommendable practice to not use it when the Zoom Level snapping mode is set to none because it can have the unintended consequence of generating an almost unlimited number of tiles. This project will be followed by other ones showing more advanced features of caching.
Map Suite Explorer
MDI Form
Topology Validation
Use Map with MVC Framework
Track Zoom In With Shift
This sample shows how you can track zoom in. this sample restrict the track zoom shape when press “Shift Key”. The restricted shape is same resolution (width/height) with map. When set the map’s snapping mode to none, the map zooms to specific zoom level without snapping Select the display area with mouse and shift.
Map Suite Explorer (ServiceEdition)
Tile Cache Generator
<div sample_otherlinks> [
map_suite_desktop_edition_miscellaneous_samples.1444462268.txt.gz · Last modified: 2015/11/05 03:37 (external edit)
