Today’s project is a tool of ENC Viewer for displaying unencrypted Electronic Navigational Charts (ENCs) available in the S-57 exchange format (*.000). This tool takes use of Map Suite HydrographyExtension to display ENC data in compliance with the latest version of ECDIS Presentation Library Edition 4.0, which is defined by the International Hydrographic Organization (IHO) in the special publication S-52. \\NOTE: the styling file “NauticalCharts.xml” for drawing S-57 (*.000) file is included in the source code package.
