map_suite_desktop_edition_google_maps_samples
Map Suite Desktop Edition Google Maps Samples
Google Maps
Desktop Edition Custom Map with Google Labels
Desktop Edition GPS to Google Map
Desktop Edition GPS to Google Map (Desktop)
Today we have the Desktop version of the Web project “GPS to Google”. In this project, we show how to display on Google Map point data coming from some GPS reading in Geodetic (Longitude/Latitude). It also shows how to set the extent of the map so that it is centered on the GPS point.
Desktop Edition Great Circle with Google Map
Desktop Edition Mini Map with Google Map At the request of a Discussion Forum user who wants to know how to use a map locator with Google Map, today we publish a Desktop project that shows how to extent the AdornmentLayer for creating a locator mini map that can use Google Map.
Desktop Edition Shapefile to Google Map
map_suite_desktop_edition_google_maps_samples.1442567864.txt.gz · Last modified: 2015/09/18 09:17 by admin
