map_suite_desktop_edition_google_maps_samples
Map_Suite_Desktop_Edition_Google_Maps_Samples
Google Maps
[[Desktop Edition Custom Map with Google Labels]]
[[Desktop Edition GPS to Google Map]]
[[Desktop Edition GPS to Google Map (Desktop)]]
Today we have the Desktop version of the Web project “GPS to Google”. In this project, we show how to display on Google Map point data coming from some GPS reading in Geodetic (Longitude/Latitude). It also shows how to set the extent of the map so that it is centered on the GPS point.
[[Desktop Edition Great Circle with Google Map]]
[[Desktop Edition Mini Map with Google Map]]
[[Desktop Edition Shapefile to Google Map]]
map_suite_desktop_edition_google_maps_samples.1440040123.txt.gz · Last modified: 2015/09/18 09:16 (external edit)
