map_suite_desktop_edition_features_bug_fixes_change_log
Map Suite Desktop Edition Features & Bug Fixes Change Log
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.DesktopEdition Namespace:
  • Added request drawing support on Overlay.
  • Fixed a bug where EditInteractiveOverlay runs into exception when dragging the first vertex of a polygon if VertexDraggingMode is Shared.
  • Fixed a bug where there is a delay of panning the map when working with MultiThread.
  • Cancel adding vertex not works by handling AddingVertex event of TrackInteractiveOverlay.
  • Fixed TrackEnding event don't works follow design.
  • Fixed StartingVertex of TrackStarting function for TrackInteractiveOverlay don't works.
  • Fix the logic for EditInteractiveOverlay, remove additional control point.
  • Added the new API SetWellKnownBinary(bytemap_suite_desktop_edition_features_bug_fixes_change_log wkb) to Feature class to allow changing the WKB of the feature.
  • Improved the performance of method bytemap_suite_desktop_edition_features_bug_fixes_change_log ShapeFile.ReadPolygon(bytemap_suite_desktop_edition_features_bug_fixes_change_log dataBytes, int startIndex).
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
Version 8.0.0.0
Release date: 06/06/2014
  • Fixed a bug where it runs into exception sometimes when remoing vertex from MultiPolygonShape.
  • Fixed a bug where something wrong with filtering other items, which is not tables, using method “GetTableName” in FileGeoDatabaseFeatureLayer.
  • Fixed a bug where something wrong with StreamLoading event of GdiPlusRasterLayer if the loaded image is in tiff format.
  • Fixed a bug where there are some incorrect format parameters in the request URI in TiledWmsRasterSource.
  • Fixed a bug in ManagedProj4Projection which happened after upgrade to 7.0.
  • Fixed a bug where the addedFeature is unable to get the tag of resshapeControlPoint.
  • Fixed a bug that will cause one shapefile could not be shared by two shapefilelayer.
  • Added support of patially refresh an area in LayerOverlay or map.
  • Improved the performance of EditInteractiveOverlay when working with large data, such as Taxes roads.
  • Added a new class MagneticDeclinationPrinterLayer to support print magnetic declination.
  • Fixed a bug where the featureDragged event is triggered during the mouse moving.
  • Added several Geoprocessing related functionalities to GeometryCollectionShape.
  • Fixed a bug where Feature Tag is missed after calling CalculateVertexControlPoints method.
  • Fixed a bug where srid is empty in oracle table after importing the features.
  • Fixed a bug where the Feature's tag is missed in some events.
  • Fixed a bug that the GraticuleAdornmentLayer numbers always has a white edge.
  • Fixed a bug where it runs into exception when reading a csv file.
  • Fixed a bug where it runs error when using MapThreadingMode.Multithreaded with TileCache.
  • Added the support of moving multiple vertexes when they are in the same place.
  • Added the support of MagneticDeclinationAdornmentLayer.
  • Fixed a bug where the application crashes if there are not enough vertexes in a line or polygon after delete.
  • Fixed the bug where the Feature's tag is missed after calling Addvertex.
  • Replaced the ECW referenced DLLs from debug version to the release one.
Version 7.0.0.0
Release date: 06/03/2013
  • Added the feature that can generate the polygon result from Isoline
  • Fixed a bug that Map.CurrentScale is not correct after Track Zoom In
  • Fixed a bug that the column value is not correct when using ShapeFileFeatureLayer.SaveToProjection
  • Fixed a bug that it's unable to resize LegendPrinterLayer
  • Fixed a bug that the icon would get trucked when using Markers
  • Fixed a bug that two InMemoryMarkerOverlays couldn't display at the same time
  • Fixed a bug that Bing maps disappears when zoom out to zoomlevel01
  • Fixed a bug that the ShapeFileFeatureLayer.StreamLoading would not be raised when file format is incorrect
  • Fixed a bug that when resizing the ImagePrinterLayer and LegendPrinterLayer the image would disappear
  • Fixed a bug that MapPrinterLayer always rendered as a bitmap
  • Fixed a bug that NullReference Exception would occur when calling TabFeatureSource.CreateTabFile with MultiPolygon
  • Fixed a bug that features draw outside MapPrinterLayer's boundary
  • Fixed a bug that the CustomZoomLevels are cleared when MapUnit is changed
  • Fixed a bug that GetAllFeatures would return incorrect features when using projection
  • Fixed a bug that the label would disappear at a slight change of extent
  • Fixed a bug that MapPrinterLayer not printing to scale
  • Fixed a bug in MarkerOverlay that the markers doesn't refresh when the Overlay.IsVisible was set to false
  • Fixed Layer.IsNegative method to apply proper color to Layer instead of Black
  • Fixed red 'x' issue for OpenStreetMapLayer and Overlay when zooming to very low scales
  • Improved standardize the Caching system across all the products
  • Modified InMemoryMarkerOverlay Features API to make API more uniform across products
Version 6.0.0.0
Release date: 05/14/2012
  • Fixed an issue where GetLineOnLine returns the wrong result.
  • Fixed an issue where the tooltips of marker are duplicated.
  • Fixed an issue where ScaleBar and ScaleLine don't match in PrinterLayer.
  • Added the method ZoomToNextExtent().
  • Fixed an issue where features cannot be selected after editing if the layer is reprojected.
  • Fixed an issue where the application crashes under visual studio 11.
  • Improved serialization of InMemoryFeatureLayer by using the class GeoSerializer.
  • Fixed an issue where System.ArgumentException is thrown when resizing LabelPrinterLayer.
  • Fixed an issue where map is not correctly printer to PDF.
  • Fixed an issue where IconImageScale in IconStyle is not printed correctly.
  • Fixed an issue where “memory access violation” exception is thrown when drawing the overlay after deserializing.
  • Fixed an issue where Manged4Projection cannot be correctly serialized.
  • Fixed an issue where projection won't be opened in GraticuleAdornmentLayer unless it is passed in through constructor.
  • Fixed an issue where Graticule Grid gets smaller when panning out of map boundary if the internal/external projection are both set to 4326.
  • Improved LegendPrinterLayer by rendering Legend using Vector Graphics.
  • Added the support for ThinkGeo's TinyGeo (.tgeo) File Format.
Version 5.5.0.49
Release date: 12/31/2011
  • Fixed an issue where markers shift when panning the map.
  • Fixed an issue where ArgumentOutOfRangeException is thrown when calling GetFeaturesWithinDistanceOf method on a projected Layer.
  • Fixed an issue where the map flashes while panning under multithreading mode with tile cache enabled.
Version 5.5.0.0
Release date: 11/14/2011
  • Fixed an issue where TrackEnded event doesn't work properly in some cases.
  • Fixed an issue where exceptions from BingMapsLayer cannot be caught.
  • Added the IsoLine Support.
Version 5.0.0.55
Release date: 7/7/2011
  • Enhanced ZoomLevel Setting
  • Fixed a bug where the layer had to be reopen after drawn in version 5.0
  • Fixed a bug where points disappeared while panning
  • Fixed a bug where the marker click event didn't work properly in some cases
  • Fixed a bug where RestrictedExtent didn't work as expected
  • Fixed a bug where WinformsMap.RestrictedExtent didn't work as expected
  • Fixed a bug where an exception was thrown while resizing within the restricted extent
Version 5.0.0.0
Release date: 5/16/2011
  • Fixed a bug where the DrawingTime of Overlays was reported incorrectly.
  • Fixed a bug where an exception was thrown when initializing the area units in multithreaded scenarios..
  • Fixed a bug in TrackInteractiveOverlay where the start point was offset when tracking a shape.
  • Fixed a bug where the Current Extent gets pretty big when passing in a very small extent.
  • Fixed a bug where the trackzoomin rectangle was still be displayed while holding the shift key even the track zoom key is set to another key.
  • Fixed a bug that threw an exception after calling Refresh when CanReshape was set to false.
  • Added BingMapsOverlay with the new way of authentication.
  • Added method GetBitmap(Single width, Single height) in wpfMap.
  • Added the property TrackZoomInLayer in the ExtentInteractiveOverlay.
  • Added a way to restrict the users extent using the Map.RestrictedExtent property.
  • Marked Serializable for GeoTiffRasterLayer, HeatLayer, GraticuleAdornmentLayer and HeatStyle.
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
  • Added MarkerOverlay which support SimpleMarkerOverlay, InmemoryMakerOverlay and FeatureSourceMakerOverlay.
  • Added OpenStreetMapOverlay to support Open Street Map.
  • Added ClusterPointStyle
Version 4.0.40.0
Release date: 6/15/2010
  • Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details.
  • Fixed issue with the ScaleTo API in BaseShape when called by a Rectangle Shape.
  • Fixed issue where an exception would be thrown when calling BuildIndex in a Turkish enviroment.
  • Fixed issue when using the UpdateColumnName API in DBF module.
  • Fixed issue involving use of Chinese fonts
  • Fixed a rounding bug in the GetPointOnALine API of LineShape.
  • Some minor API changes. See the API change log for complete details.
Version 4.0.0
Release date: 5/1/2010
  • Many core enhancements and additions as itemized here.
  • Added support and sample applications for Visual Studio 2010.
  • Increased panning performance both for WinformsMap and WpfMaps.
  • Improved WPF performance issues related to screen resolution.
  • Enhanced Overlay.Draw to display the full stack trace if an exception is thrown.
  • Fixed issue for SpatialQuery result without USA.
  • Fixed environment-related issue when using ClassBreakStyle.
  • Fixed issue where WorldMapKitWMsRasterSource would throw a thread exception.
  • Fixed issue where the Scale of InteractionArguments is always 0.
  • Fixed issue where there is no effect when the user sets a different DrawingQuilty for a layer from winforms.DrawingQuity.
  • Fixed issue where an exception is thrown when using multithreading.
  • Fixed issue where a NullReferenceException will be thrown after a CloneDeep operation because the Encoding is null.
  • Fixed issue where a WPF map cannot be zoomed in after hiding the AvalonDock.
  • Fixed issue with inheriting from TrackInterativeOverlay to remove a vertex.
  • Fixed issue where the map will not display when TileWidth is not 256.
  • Fixed issue with exceptions while drawing.
  • Fixed issue where mouseDownCount needed to be set to for TrackOverlay.
  • Fixed issue where an IOException will be thrown when using MultiThreadMode with TileCache.
  • Fixed issue where the worker thread will continue running after you call Dispose in multithreaded mode.
  • Changed the MapUnit property's default value from DecimalDegree to Unknown.
  • Changed the default DrawingExceptionMode to DrawException for WorldMapKitWmsDesktopOverlay.
  • Overall performance improvements.
  • Several API additions. See the API change log for complete details.
  • Updated the API documentation.
  • Added additional helper methods to the GeoCollection class.
  • Added better support for labeling with Asian characters.
  • Added support for Google Static Maps API v2.
  • Added simple support for Yahoo Maps.
  • Added support for heat map layers.
  • Added support for 100% managed proj Projection Library.
  • Added direct support for Map Shapes.
  • Added API to modify the column name in ShapeFileFeatureSource and ShapeFileFeatureLayer.
  • Added new API BuildIndex for MultipleShapeFileFeatureLayer
  • Included GraticuleLineLayer support and a sample application for it.
  • Enhanced the MultiShapeFileFeaturesLayer class to allow you to use files in multiple folders.
  • Enhanced the distance measuring method to use the Haversine formula.
  • Improved GeoCache performance.
  • Updated the PostgreSQL Assembly versions.
  • Exposed the DBaseFile class library.
  • Exposed the disk-based RTree Spatial Index.
  • Split up the Map Suite MergeModule into smaller and more manageable pieces.
  • Fixed issue where GetCenterPoint using NTS would return an invalid value when the polygon's width and height is 0.
  • Fixed issue regarding GetBoundingBox of GroupLayer.
  • Fixed issue where GetAllColumns also returns the Geometries column.
  • Many API additions. See the API change log for complete details.
Version 3.1.299
Release date: 11/16/2009
  • Concluded public beta and moved to final release.
  • Fixed issue where a null pointer exception is thrown when the network is not available.
  • Fixed issue where the GradientStyle does not work properly.
  • Fixed issue where snapping does not occur in Google & Virtual Earth layers.
  • Fixed issue where the TileCache is not properly cleared when the environment is set to French.
  • Fixed issue where the preview cache folder could not be created when the environment is set to French.
  • Fixed issue where an overlay does not redraw when using lock object in multi-threaded mode.
  • Fixed issue where layers would disappear when the map is set to a certain extent.
  • Several API changes. See the API change log for complete details.
  • Fixed issue where SaveToProjection is incorrect for some data.
  • Fixed issue with the DecimalDegreesHelper API GetDecimalDegreeFromDegreesMinutesSeconds.
  • Fixed caculation issue in DecimalDegreeHelper.GetDistanceFromDecimalDegrees when passing particular data.
  • Fixed issue where an exception is thrown for TAB files when the column name starts with an underscore(_).
Map Suite Desktop Edition Desktop GIS Winforms GIS .NET
map_suite_desktop_edition_features_bug_fixes_change_log.1441701760.txt.gz · Last modified: 2015/09/08 08:42 by admin
