For more information and a real-world example, please see the Map Suite discussion forum post at:
Forum Post
We also added new designs of compass in smaller version. See the attached file: Rotating Compass New Smaller Designs.zip.
In our “How Do I” apps, there is sample app that shows how to add graphs to the map using the ZedGraph library. In this project, using the same data, the US cities, we elaborate a little bit on the pie chart. You will see how to add some gradient colors to the chart, how to label the different pie slices, how to add a title etc. Zedgraph is a truly massive library for graphics and Pie chart is only one type of chart among many others. As you can add pie charts to your map, you can also add bar charts, trend charts etc. I suggest you check out this site for more info on ZedGraph
http://zedgraph.org/wiki/index.php?title=Main_Page
With Map Suite, you have the whole ZedGraph API available with an easy interface to add the graphs to the map.
For this project, in addition to the MapSuiteCore.dll, you will also need the ZedGraph.dll and ZedGraphStyleExtension.dll references. We will have several projects showing how to integrate other types of charts to your map.
Sample:Graphic Logo Adornment Layer
In this project, we create the class OledbPointFeatureSource inheriting from FeatureSource and OledbPointFeatureLayer inheriting from FeatureSource.
Displaying the North Arrow:
