Notes:
From Build 9.0.0.0 in Development Branch, the strong name File Geo Database merge module can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteFileGeoDatabaseStrongNameMergeModules2015-06-20.zip
From Build 9.0.0.0 in Development Branch, the X86 Oracle merge module can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteOracleDependenciesMergeModuleX862015-06-20.zip
From Build 9.0.0.0 in Development Branch, the X64 Oracle merge module can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteOracleDependenciesMergeModuleX642015-06-20.zip
Form Build 9.0.13.0 in Development Branch, the merge modules can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteUpdatedMergeModules2015-07-06.zip
Form Build 9.0.0.0 in Development Branch, the merge modules can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteUpdatedMergeModules2015-06-20.zip
From Build 9.0.0.0 in Development Branch, the MapSuite Cad X86 merge module can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteCadX862015-06-20.zip
From Build 9.0.0.0 in Development Branch, the MapSuite Cad X64 merge module can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteCadX642015-06-20.zip
