| Format | Support Type | Map Suite Version |
| ShapeFile1) | Read/write | 1.0 |
| MapInfo TAB | Read/write | 5.0 |
| ThinkGeo TinyGeo | Read/write | 6.0 |
| ESRI File Geodatabase | Read/write | 7.0 |
| KML (Keyhole Markup Language) | Read/write | 8.0 |
| Microsoft SQL Server Spatial 2008 and newer | Read/write | 3.0 |
| Oracle Spatial | Read/write | 3.0 |
| PostgreSQL PostGIS2) | Read/write | 3.0 |
| CAD formats .dwg and .dxf | Read | 8.0 |
| S-57 Maritime Charts | Read | 8.0 |
| GPX (GPs eXchange format) | Read | 8.0 |
| Tobin TDRBM II (.bas) | Read | 8.0 |
| ESRI Grid (.grd) | Read | 5.0 |
| SQLite | Read/write | 8.0 (refresh) |
| Mr. Sid | Read | 3.0 |
| ECW | Read | 3.0 |
| JPEG2000 | Read | 3.0 |
| GeoTIFF | Read | 3.0 |
| BMP | Read/Write | 3.0 |
| PNG | Read/Write | 3.0 |
| GIF | Read/Write | 3.0 |
| JPG | Read/Write | 3.0 |
| TIFF | Read/Write | 3.0 |
| Format/Provider | Map Suite Version | Description |
| World Map Kit Online | 3.0 | ThinkGeo's basemap based on Open Street Map Data that is displayed in most of the sample applications. You can check out what the maps look like at http://maps.thinkgeo.com |
| WMS (Web Map Service) | 6.0 | WMS is a open standard set by the OGC to consume maps over the web. |
| WFS (Web Feature Service) | 6.0 | WFS is a open standard set by the OGC. |
| Google Maps 3) | 3.0 | Google Maps |
| Bing Maps 4) | 3.0 | Bing Maps |
| NOAA Radar | 8.0 | NEXRAD Radar updated every 15 minutes covering most of the United States. |
| NOAA Weather Watches & Warnings | 8.0 | Current weather watches and warnings covering the United States. |
| NOAA Weather Stations | 8.0 | Current temperatures and other weather information from NOAA weather stations around the United States. |
Important Note: Because the FDO extension is based on a third-party open-source code library, you may experience unexpected issues beyond ThinkGeo's control when using an FDO-supported data format.
The Feature Data Objects (FDO) extension that's included with all Map Suite controls and components enables you to utilize a wide variety of vector and raster data formats in your GIS projects. With a running total of more than two dozen vector data formats and over 75 raster formats, chances are good that you'll be able to use Map Suite to work with the spatial data and imagery that you already have at your disposal.
We have made a video presentation available that explores how you can utilize the FDO extension in your Map Suite projects. For more details, including a Quick Start Guide that will show you how to use the FDO extension, take a look at this post in our Developer Blog.
By using the FDO extension included with Map Suite the following formats are also available to you:
We've just posted a handy FDO Extension QuickStart Guide that will show you how to work with the above listed data formats in your Map Suite project, so you can easily get started right away.
