map_suite_core_features_bug_fixes_change_log
  • Added masks ?? to PointStyles for diamond, circle, cross, triangle and images.
  • Added style sheets support.
  • ?? Fixed a bug that gets current zoom level in MapShapeLayer.
  • ?? Fixed an empty columns issue.
  • ?? Improved map panning performance.
  • ?? Fixed a bug in GetFeaturesOutside bounding.
  • Upgraded the LibTiff.NET to latest version??.
  • ?? Fixed a bug that TileCache is incorrect when MapType changed.
  • ?? Fixed the pink tile issue for EncryptedFileBitmapTileCache.
  • ?? Fixed the GoogleMapsOverlay draws the tiles incorrectly.
  • ?? Added Cancel to SendingWebRequestEventArgs and apply it to OSMOverlay and TiledOverlay.
  • ?? Fixed an issue that array dimensions exceeded supported range in projection.
  • ?? Fixed memory leak issue in sometimes.
  • ?? Fixed the scale bar issue.
  • Added Language property into GoogleMapsLayer and GoogleMapsOverlay??.
  • Fixed a bug that the simplified line shapes are not added to the result. (GeometryCollectionShape) ??
  • Added tiles?? tiff file format support.
  • ?? Retired Feature.IsValid method.
  • Fixed edage not match for multi raster layer if DPI not 96 for DPF?? and Printer.
  • ?? Fixed number format issue while converting from string to double and int.
map_suite_core_features_bug_fixes_change_log.1489722435.txt.gz · Last modified: 2017/03/17 03:47 by tgwikiupdate
