map_suite_core_features_bug_fixes_change_log
  • Added new api in WkbFileFeatureSource to support Wkb file features.
  • Fixed a bug where MsSql2008FeatureSource SQL statement is uppercased.
  • Fixed a bug in PrimaryOutline LineStyle's color.
  • Added WrapDateLine support to RasterLayer.
  • Fixed the bug for Google overlay customized projection.
  • Added API GetFeaturesInsideBoundingBox with filters parameter.
  • Added masks to PointStyles for diamond, circle, cross, triangle and images.
  • Added MaskMargin and MaskType to PointStyle.
  • Added support for style sheets.
  • Fixed a bug that getting current zoom level in MapShapeLayer.
  • Fixed columns are empty issue.
  • Fixed a bug where CAD file failed to rendering.
  • Fixed wms raster layer get bounding box bug.
  • Fixed TextStyle unavailable issue in DrawCore
  • Improved map panning performance.
  • Fixed a bug in GetFeaturesOutside bounding.
  • Added MultiGeometry Columns support to OracleFeatureSource.
  • Upgraded the LibTiff.NET to latest version.
  • Added embed WorldFile Support for managed tiff raster source.
  • Fixed a bug that TileCache is incorrect when MapType changed.
  • Fixed Kml FeatureLayer read local directory issue.
  • Optimized Performance on Union.
  • Fixed the black background and OutOfRangeException when opening GeoTiff.
  • Fixed the wrong zoomlevel on openstreetmap.
  • Fixed the pink tile issue for EncryptedFileBitmapTileCache.
  • Fixed the GoogleMapsOverlay draws the tiles incorrectly.
  • Added Cancel to SendingWebRequestEventArgs and apply it to OSMOverlay and TiledOverlay.
  • Fixed an issue that array dimensions exceeded supported range in projection.
  • Enhance tab font drawing effect.
  • Fixed memory leak issue in sometimes.
  • Enhancement clusterpointstyle performance.
  • Fixed the wrong color for TabFileFeatureLayer.
  • Fixed the scale bar issue.
  • Fixed the issue “value was either too large or too small for character”.
  • Enhancement to make InMemoryFeatureSource support Add/Delete/Modify column.
  • Fixed a bug where the Simplified line shapes are not added to the result. (GeometryCollectionShape)
  • Added the ArcGIS ServerRestLayer.
  • Added tiles tiff file format support.
  • Fixed WorldMapKitLayer export pdf incorrectly with TileCache.
  • Added null handling to GetInvalidReason(). Added a new API IsGeometryValid that will return the IsValid Property of the NTS Geometry.
  • Retired Feature.IsValid method.
  • Fixed a bug that app crash when the capability contains invalid bounding box.
  • Fixed tiles are incorrect with other raster layer when using projection.
  • Fixed Bing Maps not overlap with Openlayer.
  • Fixed edage not match for multi raster layer if DPI not 96 for DPF and Printer.
  • Added RowNumberPerStrip == 0 image support.
  • Fixed number format issue while converting from string to double and int.
map_suite_core_features_bug_fixes_change_log.1488354109.txt.gz · Last modified: 2017/03/01 07:41 by tgwikiupdate
