map_suite_core_features_bug_fixes_change_log
  • Added the Create WkbFile overload to WkbFileFeatureSource to support features.
  • Added Opacity support to GeoImage.
  • Fixed a bug that uppercased the SQL statement in WhereClause of MsSql2008FeatureSource
  • Fixed PrimaryOutline LineStyle color to stand out more.
  • Added WrapDateLine support to RasterLayer.
  • Fixed issue that mirror dbf file create failed.
  • Fixed the bug for Google overlay coustomize projection.
  • Added API GetFeaturesInsideBoundingBox with filters parameter.
  • Added masks to PointStyles for diamond, circle, cross, triangle and images.
  • Added MaskMargin and MaskType to PointStyle.
  • Added support for style sheets.
  • Fixed a bug that getting current zoom level in MapShapeLayer.
  • Fixed colums are empty issue.
  • Fixed the bug that CAD file failed to renderring.
  • Fixed the Kml issue in Activator.CreateInstance.
  • Fixed wms raster layer get bounding box bug.
  • Add CRS support to WMSRasterLayer.
  • Fixed TextStyle unavaliable issue in DrawCore
  • Fixed a memory leak bug in OracleFeatureSource caused by envent binding.
  • Improved map panning performance.
  • Fixed a issue in GetFeaturesOutside bounding.
  • Added MultiGeometry Columns support to OracleFeatureSource.
  • Upgraded the LibTiff.NET to latest version.
  • Added embed WorldFile Support for managed tiff raster source.
  • Fixed an issue that TileCache incorrect when MapType changed.
  • Fixed the bug NullReferenceException call StreamLoading for KmlFeatureSource.
  • Fixed Kml FeatureLayer read local directory issue.
  • Optimized Performance on Union.
  • Fixed the black background and OutOfRangeException when opening GeoTiff.
  • Add WMSTileType to make the WMSLayer support Single Tile, in which it simply send one request to the server.
  • Fixed ArgumentException when indexQuery is Null.
  • Fixed the wrong zoomlevel on openstreetmap.
  • Performance enhancement for GdiPlusGeoCanvas.
  • Enhancement ShapeFileFeatureLayer draw performance.
  • Performance enhancements.
  • Added alpha channel support for Projection Wrapper.
  • Fixed the pink tile issue for EncryptedFileBitmapTileCache.
  • Fixed the GoogleMapsOverlay draws the tiles incorrectly.
  • Added Cancel to SendingWebRequestEventArgs and apply it to OSMOverlay and TiledOverlay.
  • Fixed an issue that array dimensions exceeded supported range in projection.
  • Enhance tab font drawing effect.
  • Fixed memory leak.
  • Enhancement clusterpointstyle performance.
  • Fixed the wrong color for TabFileFeatureLayer.
  • Fixed the scale bar issue.
  • Fixed the issue “value was either too large or too small for character”.
  • Enhancement to make InMemoryFeatureSource support Add/Delete/Modify column.
  • Fixed a bug where the Simplied line shaps are not added to the result. (GeometryCollectionShape)
  • Added the ArcGIS ServerRestLayer.
  • Added tiles tiff file format support.
  • Fixed WorldMapKitLayer export pdf incorrectly with TileCache.
  • Added null handling to GetInvalidReason(). Added a new API IsGeometryValid that will return the IsValid Property of the NTS Geometry.
  • Retired Feature.IsValid method.
  • Fixed a bug that app crash when the capability contains invalid bounding box.
  • Fixed tiles are incorrect with other raster layer when using projection.
  • Enhancement shapefile performance to retain accuray when creating very large shapefiles.
  • Fixed BingMaps not overlap with Openlayer.
  • Fixed edage not match for multi raster layer if DPI not 96 for DPF and Printer.
  • Added RowNumberPerStrip == 0 image support.
  • Fixed number format issue while converting from string to double and int.
map_suite_core_features_bug_fixes_change_log.1487577903.txt.gz · Last modified: 2017/02/20 08:05 by tgwikiupdate
