map_suite_core_10.2_features_bug_fixes_change_log
ThinkGeo.MapSuite Namespace:
  • Added consuming online OSM building data for 3D rendering support and can cache the data locally
  • Added support for 3D rendering for buildings
  • Added natively support for USGS DEM data with the ability to render with embedded styles
  • Added support Interpolation for example NearestNeighbor for PlatformGeoCanvas(GDI+)
  • Added support for projecting KML from WGS84 to other projections
  • Added support for different renderring orders (by Features or by ClassBreaks) for ClassBreakStyle
  • Enhanced to optimize the accuracy of return value from “CanReproject” property in Proj4Projection
  • Enhanced to upgrade FdoRasterRasterLayer&FdoVectorFeatureLayer to use FDO 4.0
  • Fixed a bug where the type initializer for 'ThinkGeo.MapSuite.CGPatternHelper' throws “ArgumentNullException : Value cannot be null.” when GeoHatchBrush constructor is called
  • Fixed a bug where the value of last Polyline data read by FileGeoDatabaseFeatureLayer is incorrect
  • Fixed a bug where the exception “System.Reflection.TargetInvocationException was unhandled” is thrown when create table by FileGeoDatabaseFeatureLayer
  • Fixed a bug where the WmtsLayer crashed when the WMS server returns 404 error
  • Fixed a bug where GoogleMapsLayer get offset under single tile mode
  • Fixed a bug where map throw the GeoImage can't be serialized exception in some scenarios
  • Fixed a bug where InMemoryFeatureSource cannot gets correct boundingbox value by BuildIndex in certain scenarios
  • Fixed a bug where Proj4Projection constructor throws “Object reference not set to a instance of an object.” exception when the Proj4Projection's parameterless constructor is called
  • Fixed a bug where BingMapsLayer doesn't work on Android version
  • Fixed a bug the RasterLayer can't be wrapped
  • Fixed a bug where ClusterPointStyle throw “Object reference not set to an instance of an object” exception in certain scenarios
  • Fixed a bug the Compare returns a nagetive value on FeatureLocationComparer
  • Fixed a bug where the FileGdbApiWrapper return features with incorrect column names
  • Fixed a bug where the product center v10.0 can't popup in certain scenarios
map_suite_core_10.2_features_bug_fixes_change_log.1509436890.txt.gz · Last modified: 2017/10/31 08:01 by tgwikiupdate
