map_suite_core_10.2_features_bug_fixes_change_log
ThinkGeo.MapSuite Namespace:
  • Added consuming online OSM building data for 3D rendering support and can cache the data locally
  • Added support for 3D rendering for buildings
  • Added interpolation mode feature to DrawScreenImageCore of PlatformGeoCanvas
  • Added natively support for USGS DEM data with the ability to render with embedded styles
  • Added support for projecting KML from WGS84 to other projections
  • Added support for different renderring orders (by Features or by ClassBreaks) for ClassBreakStyle
  • Enhanced to optimize the accuracy of return value from “CanReproject” property in Proj4Projection
  • Enhanced to upgrade FdoRasterRasterLayer&FdoVectorFeatureLayer to use FDO 4.0
  • Fixed a bug where the type initializer for 'ThinkGeo.MapSuite.CGPatternHelper' throws “ArgumentNullException : Value cannot be null.” when GeoHatchBrush constructor is called
  • Fixed a bug the FileGeoDatabaseFeatureLayer has an incorrect value of the last line on Polyline type
  • Fixed a bug where the exception “System.Reflection.TargetInvocationException was unhandled” is thrown when create table by FileGeoDatabaseFeatureLayer
  • Fixed a bug where the WmtsLayer crashed when the WMS server returns 404 error
  • Fixed a bug where GoogleMapsLayer get offset under single tile mode
  • Fixed a bug where map throw the GeoImage can't be serialized exception in some scenarios
  • Fixed a bug the BuildIndex gets an incorrect bounding box in InMemoryFeatureSource
  • Fixed a bug where Proj4Projection constructor throws “Object reference not set to a instance of an object.” exception when the Proj4Projection's parameterless constructor is called
  • Fixed a bug the EnvironmentProvider can't get an accurate temporary folder
  • Fixed a bug the RasterLayer can't be wrapped
  • Fixed a bug the GoogleMapsLayer draw an incorrect request image on Single Tile Mode
  • Fixed a bug the ClusterPointStyle can't get converted base style
  • Fixed a bug the Compare returns a nagetive value on FeatureLocationComparer
  • Fixed a bug where the FileGdbApiWrapper return features with incorrect column names
  • Fixed a bug where the product center v10.0 can't popup in certain scenarios
map_suite_core_10.2_features_bug_fixes_change_log.1509435133.txt.gz · Last modified: 2017/10/31 07:32 by tgwikiupdate
