map_suite_adornments
Map Suite Adornments
Video Overview
Overview
Map Suite supports adornments which are graphical items that appear on top of your map and remain in a fixed position even as you pan and zoom. They are often informational, and include things like titles, scale bars, north arrows and legends. This is very helpful to viewers to better understand the context of the map.
Types of Adornments
There are seven types of adornment that are supported in Map Suite Core: Scale Bar Adornment, Scale Line Adornment, Scale Text Adornment,Logo Adornment, Graticule Adornment, Magnetic Declination Adornment, and Legend Adornment.
In this learning sample we will go over some of the most popular adornment types:
Scale Bar Adornment
Display scale bars on the map and shows the scale ratio and unit.
Border
Display scale line on the map and shows the scale ratio and unit.
Border
Display scale text on the map.It show the scale ratio and unit.
Border
Logo Adornment
The adornment should work for various kinds of logos and allow you to change the position using the AdornmentLayer's properties.
Border
Graticule Adornment
Graticule adornment can show meridians and parallels at various intervals based on the zoom level.
Border
The adornment is used for showing the angle on the horizontal plane between magnetic north (the direction in which the north end of a compass needle, corresponding to the direction of the Earth's magnetic field lines) and true north (the direction along a meridian towards the geographic North Pole).
Border
Legend Adornment
Legend adornment can show a variety of custom information.
Border
A Look at the Code
There are two projects in the Visual Studio solution. One is for the Leaflet javascript mapping library and one is for OpenLayers. In each project the AdornmentsController contains the function that loads each adornment type. The functions show how to build a adornment layer.The RefreshAdornmentLayer function and RefreshSchoolPoiLayer function will show two different drawing styles.
map_suite_adornments.1452272582.txt.gz · Last modified: 2016/01/08 17:03 by mwolffer
