map_suit_wms_server_videos_screenshots
Videos & Screenshots
Topic Attachment Description
Screenshot Gallery N/A
Introduction to the WMS Server Edition Video
Screenshot
David Rehagen, ThinkGeo CTO, narrates this video introduction to Map Suite WMS Server Edition. In the video, you'll see how WMS Server Edition works and get a first-hand walkthrough of the bundled sample applications. It's a great way to get a quick visual introduction to Map Suite WMS Server Edition and what you can do with it.
Map Suite DynamoDB Extension Technology Preview Video
Sample
Screenshot
This video will introduce you to the Map Suite DynamoDB Extension limited technology preview. This exciting new extension leverages Amazon's DynamoDB, a NoSQL cloud database technology, to store and serve GIS spatial data via the cloud. The extension's ability to use a few API calls to create a spatial table, import data and then access it without a traditional spatial database or hardware is a huge step forward.
Tile Cache Generator Video
Sample
Screenshot
This video will show you how to use the Tile Cache Generator utility to generate tile caches based on your own layers. Pre-generating tiles base on your data allows you to display the data faster than rending it from vector graphics files. It also allows you to protect your vector data by providing just the raster tiles for display purposes only. In the past pre-generating tiles required customers to build the process from scratch which was time consuming and often times inefficient. With the Tile Cache Generator we have packaged many of our best practices along with the source to allow you to tweak it to your specific situation.
Videos
WPF Edition Sample App Walkthrough Video Series
Step through the WMS Server Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Screenshot
map_suit_wms_server_videos_screenshots.1441954804.txt.gz · Last modified: 2015/09/11 07:00 by admin
