thinkgeo.mapsuite.desktopedition.maprightclickdragmode
ThinkGeo.MapSuite.DesktopEdition.MapRightClickDragMode
  • This enumeration specifies the behavior that occurs when you right-click-and-drag on the MapControl. The default value is ZoomOutWithKey.
  • For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapRightClickDragMode// == Items == Default * Summary:Default value (ZoomOutWithKey) of the enumeration. ZoomOutWithKey * Summary:This enumeration item means that the map will ZoomOut when a right-click-and-drag operation occurs. Disabled * Summary:This enumeration items means that the ZoomOut functionality for right-clicking-and-dragging will be disabled.
thinkgeo.mapsuite.desktopedition.maprightclickdragmode.txt · Last modified: 2017/03/16 21:59 (external edit)
