Have questions? Call us toll-free at 1-866-847-7510 (outside North America, call 1-785-727-4133)
Map Suite Windows Phone Edition Layers & FeatureSources Samples
From ThinkGeo Wiki
Jump to: navigation, search
Contents
Build Custom Shapefile Indexes
Screenshot Sample Product Description
Map Suite Silverlight Edition Sample Build Custom Shapefile Indexs.jpg C# Download
Need it in another language?
Services
Applies To: WindowsPhone
Desktop
Web
Silverlight
Services
Wpf
For more information and a real-world example, please see the Map Suite discussion forum post at:
http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6894/afv/topic/Default.aspx
Combining Overlays
Map Suite Silverlight Edition Sample Combining Overlays.jpg C# Download
Wpf
Desktop
Web
Silverlight
Wpf
Compass
Map Suite Silverlight Edition Sample Compas.JPG C# Download
Services
Desktop
Web
Silverlight
Services
Wpf
Create GRID
Map Suite Desktop Edition Sample Create GRID.jpg C# Download
Desktop
Desktop
Web
Silverlight
Services
Wpf
Edit Attribute Of Shapefile
Map Suite Wpf Desktop Edition Sample Edit Attribute Of Shapefile.jpg C# Download
Wpf
Desktop
Web
Silverlight
Services
Wpf
Edit Geometry Of Shapefile
Map Suite Desktop Edition Sample Edit Geometry Of Shapefile.jpg C# Download
Desktop
Desktop
Web
Silverlight
Services
Wpf
Get Data From Server With WCF
RequireDataFromServerUsingWcf.PNG C# Download
Silverlight
Desktop
Web
Silverlight
Services
Wpf
Graphic Logo for Web
Map Suite Silverlight Edition Sample Graphic Logo for Web.jpg C# Download
Web
Web
Silverlight
Heat Map
Map Suite Silverlight Edition Sample Heat Map.jpg C# Download
Desktop
Desktop
Web
Silverlight
Services
Wpf
Heat Map with earthquakes
Map Suite Silverlight Edition Sample Heat Map with earthquakes.jpg C# Download
Desktop
Desktop
Web
Silverlight
Services
Wpf
Image Stream Loading
Map Suite Silverlight Edition Sample Image Stream Loading.jpg C# Download
Desktop
Desktop
Web
Silverlight
Services
Wpf
KML Extension Web
Map Suite Silverlight Edition Sample KML Extension Web.jpg C# Download
Web
Web
Silverlight
Latitude Longitude Graticule
Map Suite Silverlight Edition Sample Latitude Longitude Graticule.jpg C# Download
Desktop
Desktop
Web
Silverlight
Services
Wpf
In this project, we create a Graticule Adorment Layer that shows Meridians and Parallels displaying through the map. Meridians are lines of longitude and they have a North South orientation. Parallels are lines of latitude and they have an East West orientation. Showing graticule for latitude and longitude is a standard way in cartography to give spatial references to the users.
MapShapes
Map Suite Silverlight Edition Sample Map Shapes.JPG C# Download
Services
Desktop
Web
Silverlight
Services
Wpf
To fill this gap, we are presenting a project for a simple MapShapeLayer. This is a simple version of a more powerful one that we will include as part of the core framework in the near future. What really struck us when we were creating this new Layer was just how easy it was to do! It is a testament to our 3.0 framework and we decided to include the section below on how we implemented it. Notes from the developer:
Mini Map Adornment Layer
Map Suite Silverlight Edition Sample Mini Map With Adornment Layer.JPG C# Download
Services
Desktop
Web
Silverlight
Services
Wpf
Multi Geo Raster Layer
No screenshot.jpg C# Download
Services
Desktop
Web
Silverlight
Services
Wpf
Multi Index
Map Suite Silverlight Edition Sample Multi Index.jpg C# Download
Services
Desktop
Web
Silverlight
Services
Wpf
Native TAB File Suppport
TabFileSupport.jpg C# Download
Desktop
Desktop
Web
Silverlight
Services
Wpf
North Arrow
Map Suite Silverlight Edition Sample North Arrow.JPG C# Download
Services
Destop
Web
Silverlight
Services
Wpf
Rotating the map:
Displaying the North Arrow:
Numbered Grid
Map Suite Silverlight Edition Sample Numbered Grid.jpg C# Download
Desktop
Desktop
Web
Silverlight
Services
Wpf
Oledb Point FeatureSource
Map Suite Silverlight Edition Sample Oledb Point FeatureSource.JPG C# Download
Services
Desktop
Web
Silverlight
Services
Wpf
In this project, we create the class OledbPointFeatureSource inheriting from FeatureSource and OledbPointFeatureLayer inheriting from FeatureSource.
Scale Bar
Map Suite Silverlight Edition Sample Scale Bar.jpg C# Download
Services
Desktop
Web
Silverlight
Services
Wpf
Desktop
Desktop
Web
Silverlight
Services
Wpf
Swine Flu
Map Suite Silverlight Edition Sample Swine Flu.jpg C# Download
Services
Desktop
Web
Silverlight
Services
Wpf
On the web site http://www.mapcruzin.com/free-download-h1n1-swine-flu-arcgis-shapefile.htm, it is possible to download point based shapefiles of swine flu occurrences in the world. While this information is valuable, it is a little difficult to display it at world level. At high zoom levels, all the points are on top of each other making the map very difficult to read and get overall information of the swine flu situation at the world level as you can see in the image with the map of the upper left.
Watermark Adornment Layer
Map Suite Silverlight Edition Sample Watermark Adornment Layer.JPG C# Download
Services
Desktop
Web
Silverlight
Services
Wpf
Zedgraph
Map Suite Silverlight Edition Sample Zedgraph.jpg C# Download
Services
Desktop
Web
Silverlight
Services
Wpf
In our “How Do I” apps, there is sample app that shows how to add graphs to the map using the ZedGraph library. In this project, using the same data, the US cities, we elaborate a little bit on the pie chart. You will see how to add some gradient colors to the chart, how to label the different pie slices, how to add a title etc. Zedgraph is a truly massive library for graphics and Pie chart is only one type of chart among many others. As you can add pie charts to your map, you can also add bar charts, trend charts etc. I suggest you check out this site for more info on ZedGraph
http://zedgraph.org/wiki/index.php?title=Main_Page
With Map Suite, you have the whole ZedGraph API available with an easy interface to add the graphs to the map.
For this project, in addition to the MapSuiteCore.dll, you will also need the ZedGraph.dll and ZedGraphStyleExtension.dll references. We will have several projects showing how to integrate other types of charts to your map.
Personal tools
Variants
Actions
Products
Data
Add Ons
Navigation
Toolbox
Learn More About Map Suite, Download a Free Trial, or Buy Now
GIS Developer Components for .NET
Map Suite Extensions & Add-Ons
Map Data Sets & Icons
Try Map Suite Free
Map Suite Online Store
sales@thinkgeo.com
1-866-847-7510 (Toll-Free)
1-785-727-4133 (Outside North America)
ThinkGeo LLC
2801 Network Blvd. Suite 215
Frisco, TX 75034
Map Suite Support Center
