map_suite_performance_guide
Map Suite Performance Guide
This guide is a work in progress.
The Map Suite Performance Guide was designed to be applicable across the Map Suite product line. In some instances there may be minor coding difference between them and you may need to slightly tweak the code examples.
Data
Building Spatial Indexes
Simply Data
Splitting Data by Classification
Grid Detailed Polygons
It is important to note that you want to change your styling so that you only fill in the new polygons and do not draw a border around them. For drawing the actual border, in the case of a tile intersecting the real border, we have another approach. In our utility we enable you to also convert your large polygon files to a split-up line file. Using this method you can display a line file and style it for the border, and then display a fill-style Shapefile for the fill. In this way your drawing speed will improve greatly. A great way to find issues is to look at the render times per layer to see where bottlenecks are. On each layer there is a DrawingTime property you can check after you draw. This is invaluable to troubleshoot drawing performance related issues.
To help create the grid polygon layers, we have created a utility to assist you. I suggest you play around with the scale and view the output to see what is going on. The source is included so you can see what is happening and integrate this into other processes as necessary. One important thing to mention is that I suggest doing this with nearly all of your high point-count polygon files. Many times it is certain files that seem fine which are actually taking up all the rendering time.
Before Optimization
Before Optimization
After Optimization
After Optimization
Resources:
Remove Unnecessary Data
Projecting Data
Styles
Choosing Scales
Area Styles
Line Styles
Value Styles
Class Break Styles
Labeling
Custom Styles
Slower Styles
Layers & Overlays
Gathering Performance Data
InMemoryFeatureLayer
Pinning Files in Memory
Limiting Number of Features Drawn
Grouping Layers
Dynamic Features
Pregenerated Tile Cache
Pregenerating a tile cache allows your to render your vector data to raster tiles ahead of time for faster consumption in the future. This systems is similar the ways that the large mapping providers such as Bing and Google export their data for consumption. To help we have create the Tile Cache Generator utility, including source, which encapsulates best practices and many useful features when tiling your data. Below is additional information on how tiling works, when you might use it, and its advantages and trade-offs.
Advantages
There are a number of advantages to pre-creating tiles but the biggest advantage to most of our customers is improved display performance. Rendering vector data takes quite a bit of processing power depending on the number of records to draw, the size of the image and the complexity of the styles used. In contrast once a tile has been rendered its display time is fixes regardless of the other factors listed above. The difference is especially pronounces as the vector and style complexity rise.
Another benefit to tiling is the ability to just distribute the raster data and not the vector data. In many cases the precise vector data may be propitiatory and by providing the image you are not divulging the exact data in a format that can be easily reverse engineered.
Trade offs
The main problem with tiling is that the raster image represents a point in time regarding when the image was generated. If the vector data is updated you need to re-generate the tiles to take that into account. This may cause you the need to create a strategy to periodically refresh the tiles based on how frequently your data changes. There are a number of ways this can be done efficiently such as re-generating only the tiles within the bounding box of the features that have changed.
Common Scenarios
Temporary Tiling
Pre Tiling
GeoCache
WMS
map_suite_performance_guide.txt · Last modified: 2017/03/17 02:09 by tgwikiupdate
