thinkgeo.mapsuite.silverlightedition.mousemovedtrackinteractiveoverlayeventargs [2015/09/21 03:29] admin |
thinkgeo.mapsuite.silverlightedition.mousemovedtrackinteractiveoverlayeventargs [2017/03/16 21:59] (current) |
====== ThinkGeo.MapSuite.SilverlightEdition.MouseMovedTrackInteractiveOverlayEventArgs ====== | ====== ThinkGeo.MapSuite.SilverlightEdition.MouseMovedTrackInteractiveOverlayEventArgs ====== | ||
Provides data for the MouseMoved. event. | Provides data for the MouseMoved. event. | ||
===== Inheritance Hierarchy ===== | ===== Inheritance Hierarchy ===== | ||
Line 9: | Line 12: | ||
** {{wiki:PublicMethod.gif|}} MouseMovedTrackInteractiveOverlayEventArgs() ** | ** {{wiki:PublicMethod.gif|}} MouseMovedTrackInteractiveOverlayEventArgs() ** | ||
- | This is the default constructor of this parameter. | + | * //This is the default constructor of this parameter.// |
== Remarks == | == Remarks == | ||
- | If you use this constructor, you have to set the properties manually before use. | + | * //If you use this constructor, you have to set the properties manually before use.// |
== Parameters == | == Parameters == | ||
** {{wiki:PublicMethod.gif|}} MouseMovedTrackInteractiveOverlayEventArgs(Vertex,Feature) ** | ** {{wiki:PublicMethod.gif|}} MouseMovedTrackInteractiveOverlayEventArgs(Vertex,Feature) ** | ||
- | This is the commonly used constructor. | + | * //This is the commonly used constructor.// |
- | N/A | + | * //N/A// |
* //movedVertex// | * //movedVertex// | ||
Line 33: | Line 36: | ||
** {{wiki:PublicMethod.gif|}} ToString() ** | ** {{wiki:PublicMethod.gif|}} ToString() ** | ||
== Return Value == | == Return Value == | ||
Line 45: | Line 48: | ||
** {{wiki:PublicMethod.gif|}} Equals(Object) ** | ** {{wiki:PublicMethod.gif|}} Equals(Object) ** | ||
Line 61: | Line 64: | ||
** {{wiki:PublicMethod.gif|}} GetHashCode() ** | ** {{wiki:PublicMethod.gif|}} GetHashCode() ** | ||
Line 73: | Line 76: | ||
** {{wiki:PublicMethod.gif|}} GetType() ** | ** {{wiki:PublicMethod.gif|}} GetType() ** | ||
Line 86: | Line 89: | ||
** {{wiki:ProtectedMethod.gif|}} Finalize() ** | ** {{wiki:ProtectedMethod.gif|}} Finalize() ** | ||
Line 98: | Line 101: | ||
** {{wiki:ProtectedMethod.gif|}} MemberwiseClone() ** | ** {{wiki:ProtectedMethod.gif|}} MemberwiseClone() ** | ||
