thinkgeo.mapsuite.silverlightedition.extentchangingeventargs [2015/08/20 03:08] 127.0.0.1 external edit |
thinkgeo.mapsuite.silverlightedition.extentchangingeventargs [2017/03/16 21:59] (current) |
====== ThinkGeo.MapSuite.SilverlightEdition.ExtentChangingEventArgs ====== | ====== ThinkGeo.MapSuite.SilverlightEdition.ExtentChangingEventArgs ====== | ||
- | <!-- Class --> | ||
- | This class represents the event arguments for the ExtentChanging event. | ||
- | === Remarks === | ||
This class represents the event arguments for the ExtentChanging event. | This class represents the event arguments for the ExtentChanging event. | ||
===== Inheritance Hierarchy ===== | ===== Inheritance Hierarchy ===== | ||
- | *System.Object | + | *System.Object |
- | **System.EventArgs | + | *System.EventArgs |
- | ***[[ThinkGeo.MapSuite.SilverlightEdition.ExtentChangingEventArgs]] | + | ***ThinkGeo.MapSuite.SilverlightEdition.ExtentChangingEventArgs** |
===== Members Summary ===== | ===== Members Summary ===== | ||
==== Public Constructors ==== | ==== Public Constructors ==== | ||
- | ^ Name ^ Parameters ^ DeclaringType ^ Summary ^ | + | ** {{wiki:PublicMethod.gif|}} ExtentChangingEventArgs() ** |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#ExtentChangingEventArgs()|ExtentChangingEventArgs]] | | | This is the constructor of ExtentChangingEventArgs class. | | + | |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#ExtentChangingEventArgs(RectangleShape, Double)|ExtentChangingEventArgs]] | [[ThinkGeo.MapSuite.SilverlightCore.RectangleShape|RectangleShape]], Double | | This is the constructor of ExtentChangingEventArgs class. | | + | |
- | ==== Protected Constructors ==== | + | * //This is the constructor of ExtentChangingEventArgs class.// |
- | ^ Name ^ Parameters ^ DeclaringType ^ Summary ^ | + | == Remarks == |
+ | * //This is the constructor of ExtentChangingEventArgs class.// | ||
+ | == Parameters == | ||
+ | <div newline></div> | ||
+ | ** {{wiki:PublicMethod.gif|}} ExtentChangingEventArgs(RectangleShape,Double) ** | ||
+ | == Remarks == | ||
+ | * //N/A// | ||
+ | * //currentExtent// | ||
+ | * Type:[[ThinkGeo.MapSuite.SilverlightCore.RectangleShape|RectangleShape]] | ||
+ | * Description:A RectangleShape value which is current extent before the extent changing. | ||
+ | * //currentScale// | ||
+ | * Type:Double | ||
+ | * Description:A value which is current scale before the extent changing. | ||
+ | ==== Protected Constructors ==== | ||
==== Public Methods ==== | ==== Public Methods ==== | ||
- | ^ Name ^ Parameters ^ DeclaringType ^ Summary ^ | + | ** {{wiki:PublicMethod.gif|}} ToString() ** |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#Equals(Object)|Equals]] | Object | Object | | | + | |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#GetHashCode()|GetHashCode]] | | Object | | | + | |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#GetType()|GetType]] | | Object | | | + | |
- | | {{wiki:PublicMethod.gif|Public Method}}[[#ToString()|ToString]] | | Object | | | + | |
- | ==== Protected Methods ==== | + | * //N/A// |
- | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#Finalize()|Finalize]] | | Object | | | + | * //N/A// |
- | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#MemberwiseClone()|MemberwiseClone]] | | Object | | | + | |
- | ==== Public Properties ==== | + | == Return Value == |
- | ^ Name ^ Return ^ DeclaringType ^ Summary ^ | + | * Type:String |
- | | {{wiki:PublicProperty.gif|Public Property}}[[#CurrentExtent|CurrentExtent]] | [[ThinkGeo.MapSuite.SilverlightCore.RectangleShape|RectangleShape]] | | Gets or sets current extent before the extent changes. | | + | * Description:N/A |
- | | {{wiki:PublicProperty.gif|Public Property}}[[#CurrentScale|CurrentScale]] | Double | | Gets or sets current scale before the extent changes. | | + | |
- | ==== Protected Properties ==== | + | == Parameters == |
- | ^ Name ^ Return ^ DeclaringType ^ Summary ^ | + | <div newline></div> |
+ | ** {{wiki:PublicMethod.gif|}} Equals(Object) ** | ||
- | ==== Public Events ==== | + | * //N/A// |
- | ^ Name ^ Event Arguments ^ DeclaringType ^ Summary ^ | + | == Remarks == |
+ | * //N/A// | ||
- | ===== Public Constructors ===== | + | == Return Value == |
- | ==== ExtentChangingEventArgs() ==== | + | * Type:Boolean |
- | This is the constructor of ExtentChangingEventArgs class. | + | * Description:N/A |
- | === Overloads === | + | |
- | This is the constructor of ExtentChangingEventArgs class. | + | |
- | === Remarks === | + | |
- | === Parameters === | + | |
- | ^ Name ^ Type ^ Description ^ | + | |
- | [[#Public Constructors|Go Back]] | + | == Parameters == |
- | ==== ExtentChangingEventArgs(RectangleShape, Double) ==== | + | * //obj// |
- | This is the constructor of ExtentChangingEventArgs class. | + | * Type:Object |
- | === Overloads === | + | * Description:N/A |
- | | currentExtent | [[ThinkGeo.MapSuite.SilverlightCore.RectangleShape|RectangleShape]]<!-- ThinkGeo.MapSuite.SilverlightCore.RectangleShape --> | A RectangleShape value which is current extent before the extent changing. | | + | |
- | | currentScale | Double<!-- System.Double --> | A value which is current scale before the extent changing. | | + | |
- | [[#Public Constructors|Go Back]] | + | <div newline></div> |
- | ===== Protected Constructors ===== | + | ** {{wiki:PublicMethod.gif|}} GetHashCode() ** |
- | ===== Public Methods ===== | + | |
- | ==== Equals(Object) ==== | + | |
- | === Return Value === | + | |
- | ^ Return Type ^ Description ^ | + | |
- | | Boolean<!-- System.Boolean --> | | | + | |
- | === Parameters === | + | * //N/A// |
- | ^ Name ^ Type ^ Description ^ | + | == Remarks == |
- | | obj | Object<!-- System.Object --> | | | + | * //N/A// |
- | <!-- System.Object --> | + | == Return Value == |
- | [[#Public Methods|Go Back]] | + | * Type:Int32 |
- | ==== GetHashCode() ==== | + | * Description:N/A |
- | | Int32<!-- System.Int32 --> | | | + | |
- | === Parameters === | + | == Parameters == |
- | ^ Name ^ Type ^ Description ^ | + | <div newline></div> |
+ | ** {{wiki:PublicMethod.gif|}} GetType() ** | ||
- | <!-- System.Object --> | + | * //N/A// |
- | [[#Public Methods|Go Back]] | + | == Remarks == |
- | ==== GetType() ==== | + | * //N/A// |
- | | Type<!-- System.Type --> | | | + | |
- | === Parameters === | + | == Return Value == |
- | ^ Name ^ Type ^ Description ^ | + | * Type:Type |
+ | * Description:N/A | ||
- | <!-- System.Object --> | + | == Parameters == |
- | [[#Public Methods|Go Back]] | + | <div newline></div> |
- | ==== ToString() ==== | + | ==== Protected Methods ==== |
- | === Return Value === | + | ** {{wiki:ProtectedMethod.gif|}} Finalize() ** |
- | | String<!-- System.String --> | | | + | |
+ | * //N/A// | ||
- | [[#Public Methods|Go Back]] | + | * Type:Void |
- | ===== Protected Methods ===== | + | * Description:N/A |
- | ==== Finalize() ==== | + | |
- | | Void<!-- System.Void --> | | | + | |
+ | ** {{wiki:ProtectedMethod.gif|}} MemberwiseClone() ** | ||
- | [[#Protected Methods|Go Back]] | + | == Remarks == |
- | ==== MemberwiseClone() ==== | + | * //N/A// |
- | | Object<!-- System.Object --> | | | + | |
- | ^ Name ^ Type ^ Description ^ | + | * Type:Object |
+ | ==== Public Properties ==== | ||
+ | ** {{wiki:PublicProperty.gif|}} CurrentExtent ** | ||
- | <!-- System.Object --> | ||
- | [[#Protected Methods|Go Back]] | ||
- | ===== Public Properties ===== | ||
- | ==== CurrentExtent ==== | ||
Gets or sets current extent before the extent changes. | Gets or sets current extent before the extent changes. | ||
- | === Remarks === | + | == Remarks == |
- | === Return Value === | + | == Return Value == |
- | ^ Return Type ^ | + | * Type:[[ThinkGeo.MapSuite.SilverlightCore.RectangleShape|RectangleShape]] |
- | | [[ThinkGeo.MapSuite.SilverlightCore.RectangleShape|RectangleShape]]<!-- ThinkGeo.MapSuite.SilverlightCore.RectangleShape --> | | + | |
+ | ** {{wiki:PublicProperty.gif|}} CurrentScale ** | ||
- | <!-- ThinkGeo.MapSuite.SilverlightEdition.ExtentChangingEventArgs --> | ||
- | [[#Public Properties|Go Back]] | ||
- | ==== CurrentScale ==== | ||
Gets or sets current scale before the extent changes. | Gets or sets current scale before the extent changes. | ||
- | ^ Return Type ^ | + | * Type:Double |
- | | Double<!-- System.Double --> | | + | |
- | <!-- ThinkGeo.MapSuite.SilverlightEdition.ExtentChangingEventArgs --> | + | ==== Protected Properties ==== |
- | [[#Public Properties|Go Back]] | + | ==== Public Events ==== |
- | ===== Protected Properties ===== | + | |
- | ===== Public Events ===== | + | |
- | __NOTOC__ | + | |
- | [[Category:SilverlightEdition]] | + | |
- | [[Category:ThinkGeo.MapSuite.SilverlightEdition]] | + | |
- | [[Category:UpdateDocumentation]] | + | |
