map_suite_webapi_edition_features_bug_fixes_change_log [2015/09/09 08:46] admin [Map_Suite_WebAPI_Edition_Features_&_Bug_Fixes_Change_Log] |
map_suite_webapi_edition_features_bug_fixes_change_log [2015/09/09 08:54] (current) admin [Version 9.0.0.0] |
| Line 6: | Line 6: | ||
| - | *Fixed a bug where there are something wrong with parsing the namespace of WMS capabilities file. | + | *Fixed a bug where there are something wrong with parsing the namespace of WMS capabilities file. |
| - | *Fixed a bug where the EcwRasterLayer runs into memory leak exception. | + | *Fixed a bug where the EcwRasterLayer runs into memory leak exception. |
| - | *Fixed a bug where the GetBoundingBoxCore method of MsSqlFeatureSource runs into exception. | + | *Fixed a bug where the GetBoundingBoxCore method of MsSqlFeatureSource runs into exception. |
| - | *Updated the unmanaged Proj4 dependency to the latest version 4.8. | + | *Updated the unmanaged Proj4 dependency to the latest version 4.8. |
| - | *Fixed a bug where ECW file path name is case-sensitive. | + | *Fixed a bug where ECW file path name is case-sensitive. |
| - | *Added a new class of ScaleLinePrinterLayer to print scale lines. | + | *Added a new class of ScaleLinePrinterLayer to print scale lines. |
| - | *Added new class of ScaleTextAdornmentLayer to Map Suite Core. | + | *Added new class of ScaleTextAdornmentLayer to Map Suite Core. |
| - | *Added a new class of ScaleTextPrinterLayer to print scale text. | + | *Added a new class of ScaleTextPrinterLayer to print scale text. |
| - | *Fixed a bug where there are something wrong with initializing the omerc projection. | + | *Fixed a bug where there are something wrong with initializing the omerc projection. |
| - | *Fixed a bug where the Dispose method of UnmanagedProj4Projection runs into exception. | + | *Fixed a bug where the Dispose method of UnmanagedProj4Projection runs into exception. |
| - | *Fixed a bug where selecting LabelPrinterLayer runs into exception. | + | *Fixed a bug where selecting LabelPrinterLayer runs into exception. |
| - | *Fixed a bug where MrsidRasterLayer runs into memory leak problem. | + | *Fixed a bug where MrsidRasterLayer runs into memory leak problem. |
| - | *Fixed a bug where the Jpeg2000RasterSource runs into memory leak issue. | + | *Fixed a bug where the Jpeg2000RasterSource runs into memory leak issue. |
| - | *Fixed a bug where it runs into exception when building the index of KmlLayer. | + | *Fixed a bug where it runs into exception when building the index of KmlLayer. |
| - | *Fixed a bug that the deployed version of WebEddition, MvcEdition, SilverlightEdition and WmsEdition runs into “Unlicensed for runtime” . | + | *Fixed a bug that the deployed version of WebEddition, MvcEdition, SilverlightEdition and WmsEdition runs into “Unlicensed for runtime” . |
| - | *Added new API for changing the color of Grid lines in ScaleBarAdormentLayer. | + | *Added new API for changing the color of Grid lines in ScaleBarAdormentLayer. |
| - | *Fixed a bug where the WmtsLayer runs into exception, as the code of clearing the tile matrix is incorrect. | + | *Fixed a bug where the WmtsLayer runs into exception, as the code of clearing the tile matrix is incorrect. |
| - | *Added support of requesting tiles using UrlTemplate of resource URL in WmtsLayer. | + | *Added support of requesting tiles using UrlTemplate of resource URL in WmtsLayer. |
| - | *Fixed a bug where reading Shapefile runs into exception if the decimal length of DBFColumn is bigger than 15. | + | *Fixed a bug where reading Shapefile runs into exception if the decimal length of DBFColumn is bigger than 15. |
| - | *Fixed a bug where the IsolineLayer runs into exception sometimes when IsolineType is ClosedAsPolygon. | + | *Fixed a bug where the IsolineLayer runs into exception sometimes when IsolineType is ClosedAsPolygon. |
| - | *Fixed a bug where the scales of tile matrix in WmtsLayer on server side are different from the ones on client side. | + | *Fixed a bug where the scales of tile matrix in WmtsLayer on server side are different from the ones on client side. |
| - | *Fixed a bug where KmlLayer runs into exception when loading KML file with the encrypted dlls. | + | *Fixed a bug where KmlLayer runs into exception when loading KML file with the encrypted dlls. |
| - | *Enhancement OracleFeatureSource, only create one assembly instance. | + | *Enhancement OracleFeatureSource, only create one assembly instance. |
| - | *Fixed a bug where the MagneticNorthLineStyle cannot be serialized. | + | *Fixed a bug where the MagneticNorthLineStyle cannot be serialized. |
| - | *Fixed a bug where the drawn tile images are mismatch each other when applying FileBitmapTileCache. | + | *Fixed a bug where the drawn tile images are mismatch each other when applying FileBitmapTileCache. |
| - | *Added more projection support to WMTS besides the support of EPSG:3857 and EPSG:4326. | + | *Added more projection support to WMTS besides the support of EPSG:3857 and EPSG:4326. |
| - | *Fixed a bug where it returns incorrect class breaks if there is only one ClassBreak item in ClassBreakStyle. | + | *Fixed a bug where it returns incorrect class breaks if there is only one ClassBreak item in ClassBreakStyle. |
| - | *Fixed a bug where the GridFeatureSource generates Gridfile with CurrentCulture but Read GridFile with InviriantCulture. | + | *Fixed a bug where the GridFeatureSource generates Gridfile with CurrentCulture but Read GridFile with InviriantCulture. |
| - | *Fixed a bug where the scales of cached tiles are incorrect if OpenStreetMapLayer works with MultiThread mode. | + | *Fixed a bug where the scales of cached tiles are incorrect if OpenStreetMapLayer works with MultiThread mode. |
| - | *Fixed a bug where it runs into exception when initializing the TileCache of OpenStreetMapLayer as null. | + | *Fixed a bug where it runs into exception when initializing the TileCache of OpenStreetMapLayer as null. |
| - | *Fixed a bug where it runs into exception if the readed KML file includes the bool values. | + | *Fixed a bug where it runs into exception if the readed KML file includes the bool values. |
| - | *Fixed a bug where the height of LegendAdormentLayer/LegendPrinterAdormentLayer is incorrect when the ResizeMode is Fixed. | + | *Fixed a bug where the height of LegendAdormentLayer/LegendPrinterAdormentLayer is incorrect when the ResizeMode is Fixed. |
| - | *Fixed a bug where there are something wrong with CodeGenerator. | + | *Fixed a bug where there are something wrong with CodeGenerator. |
| - | *Improved performance of drawing GraticuleAdornmentLayer. | + | *Improved performance of drawing GraticuleAdornmentLayer. |
| - | *Changed the default value of LegendContentResizeMode to Fixed. | + | *Changed the default value of LegendContentResizeMode to Fixed. |
| - | *Fixed bug that WMS don't parse response XML which describe error information. | + | *Fixed bug that WMS don't parse response XML which describe error information. |
| - | *Fixed bug GetWellKnownText for lineshape haven't been convert to Invariant Culture. | + | *Fixed bug GetWellKnownText for lineshape haven't been convert to Invariant Culture. |
| - | *Remove toUpper for whereClause of MsSql2008FeatureLayer. | + | *Remove toUpper for whereClause of MsSql2008FeatureLayer. |
| - | *Fixed a bug where the ClientId and PrivateKey of GoogleMapsLayer doesn't work with SingleTile. | + | *Fixed a bug where the ClientId and PrivateKey of GoogleMapsLayer doesn't work with SingleTile. |
| - | *Improved the GeoCoderGenerator. | + | *Improved the GeoCoderGenerator. |
| - | *Added support of support custom spatial index name in mssqlfeaturelayer. | + | *Added support of support custom spatial index name in mssqlfeaturelayer. |
| - | *Fixed a bug where the request tile size is not equal to the size of map with SingleTile. | + | *Fixed a bug where the request tile size is not equal to the size of map with SingleTile. |
| - | *Fixed a bug where the method GetAllMapShape of KmlFeatureLayer runs into exception. | + | *Fixed a bug where the method GetAllMapShape of KmlFeatureLayer runs into exception. |
| - | *Improved the IsoLine result generated by removing the holes at the center of IsonLine. | + | *Improved the IsoLine result generated by removing the holes at the center of IsonLine. |
| - | *Added the embedded TAB style support. | + | *Added the embedded TAB style support. |
| - | *Fixed a bug where ProjectionFromSphericalMercator property doesn't work. | + | *Fixed a bug where ProjectionFromSphericalMercator property doesn't work. |
| - | *Added Attribution to all layers and Overlays. | + | *Added Attribution to all layers and Overlays. |
| - | *Fxied a bug where the MagneticDeclinationAdornmentLayer runs into memory issue. | + | *Fxied a bug where the MagneticDeclinationAdornmentLayer runs into memory issue. |
| - | *Added the new API SetWellKnownBinary(byte[[]] wkb) to Feature class to allow changing the WKB of the feature. | + | *Added the new API SetWellKnownBinary(byte wkb) to Feature class to allow changing the WKB of the feature. |
| - | *Improved the performance of method byte[[]] ShapeFile.ReadPolygon(byte[[]] dataBytes, int startIndex). | + | *Improved the performance of method byte ShapeFile.ReadPolygon(byte dataBytes, int startIndex). |
| - | *Removed the using JTS in Feature to Shape conversion(BaseShape.FromWellKnownBinary, BaseShape.CreateShapeFromWellKnownData). | + | *Removed the using JTS in Feature to Shape conversion(BaseShape.FromWellKnownBinary, BaseShape.CreateShapeFromWellKnownData). |
| - | *Added enhancements to OpenStreetMapLayer and OpenStreetMapOverlay to make sure the exception can be thrown out. | + | *Added enhancements to OpenStreetMapLayer and OpenStreetMapOverlay to make sure the exception can be thrown out. |
| - | *Added Leader Lines. | + | *Added Leader Lines. |
| - | *Enhanced the Best Placement algorithm. | + | *Enhanced the Best Placement algorithm. |
| - | *Added an Abbreviation Dictionary. For example, add "University" with "Univ" to the Abbreviation Dictionary and "University" will be abbreviated when displayed. | + | *Added an Abbreviation Dictionary. For example, add "University" with "Univ" to the Abbreviation Dictionary and "University" will be abbreviated when displayed. |
| - | *Added Max Nudging parameter to specify how far a label can be moved. | + | *Added Max Nudging parameter to specify how far a label can be moved. |
| - | *The unit for Drawing Margin is now pixels instead of percentage. | + | *The unit for Drawing Margin is now pixels instead of percentage. |
| - | *Geohashing APIs - Allows sorting of GeoFeatures for performance gains. Shapefiles of features that are in proximity are stored on the same section of the disk. | + | *Geohashing APIs - Allows sorting of GeoFeatures for performance gains. Shapefiles of features that are in proximity are stored on the same section of the disk. |
| - | *Standard color access for Geocolors, brushes, and pins has been streamlined. | + | *Standard color access for Geocolors, brushes, and pins has been streamlined. |
| - | *New Projection API to find local UTM Zone for any feature. No longer need to look up UTM Zone manually. | + | *New Projection API to find local UTM Zone for any feature. No longer need to look up UTM Zone manually. |
| - | *Added ability to save and import style files from GIS Editor to Map Suite. | + | *Added ability to save and import style files from GIS Editor to Map Suite. |
| - | *One-way road line style now available. | + | *One-way road line style now available. |
| - | *More filter conditions added for RegEx. It is now simpler to use. | + | *More filter conditions added for RegEx. It is now simpler to use. |
| - | *Added R-Tree Indexing for KML feature layers. | + | *Added R-Tree Indexing for KML feature layers. |
| - | *Gave ability to modify well-known binary on a feature. Now possible to directly access and modify WKB. | + | *Gave ability to modify well-known binary on a feature. Now possible to directly access and modify WKB. |
| - | *Can now add column value data without defining it up front to Map Shapes and Edit Shapes. | + | *Can now add column value data without defining it up front to Map Shapes and Edit Shapes. |
| - | *Added Boundary Solution Parcel feature layer. | + | *Added Boundary Solution Parcel feature layer. |
| - | *Created new APIs for accurate measurements regardless of projection. | + | *Created new APIs for accurate measurements regardless of projection. |
| - | *Enhanced Tile Cache - new APIs allow expiration by size, date, etc. | + | *Enhanced Tile Cache - new APIs allow expiration by size, date, etc. |
| - | *Created Well Known Binary feature layer type for better performance, especially on Android and iOS. | + | *Created Well Known Binary feature layer type for better performance, especially on Android and iOS. |
| - | *New Printing APIs allow switching between page and world coordinates. | + | *New Printing APIs allow switching between page and world coordinates. |
| - | *ScaleBar and ScaleLine - can set a text style to control the font and look. | + | *ScaleBar and ScaleLine - can set a text style to control the font and look. |
| =====Version 8.0.0.150===== | =====Version 8.0.0.150===== | ||
