map_suite_routing_miscellaneous_samples [2015/12/21 03:09] tgwikiupdate [Routing Index Generator] |
map_suite_routing_miscellaneous_samples [2016/11/30 21:06] ryanduan [Routing Index Generator] Updated description and files |
Line 8: | Line 8: | ||
<div download_viewsource_buttons> | <div download_viewsource_buttons> | ||
[[Source_Code_Routing_Index_Generator_CS_100325.zip|View Source]] | [[Source_Code_Routing_Index_Generator_CS_100325.zip|View Source]] | ||
- | {{filehistory:Routing_Index_Generator|C# Download}} | + | {{filehistory:Routing_Index_Generator.zip|C# Download}} |
<div sample_otherlinks> | <div sample_otherlinks> | ||
Line 15: | Line 15: | ||
[[Map Suite Samples Alternate Languages | Need it in another language?]] | [[Map Suite Samples Alternate Languages | Need it in another language?]] | ||
- | The Map Suite Routing Index Generator is a new utility that lets you generate the routing index files (“.rtg” and “.rtx”) for your ESRI shape file, they will be used by Map Suite Routing Extension to calculate routes and driving directions. This utility allows you to specify the one-way information, configure the road speed and the type of routes you would like to calculate. It’s easy for you to add the code for dealing other road situations. | + | The Map Suite Routing Index Generator is a utility that will allow you to generate routing index files (".rtg" and ".rtx") from ESRI shapefiles and .sqlite databases. These routing index files will be used by the Map Suite Routing Extension in order to calculate routes and driving directions. This utility allows you to specify things that one-way road information, as well as configuring the road speed and type of routes you would like to calculate. It is easily extendable to allow you to add code to deal with other routing situations. This version of the RoutingIndexGenerator requires v9.0.515.0 or higher of both MapSuiteCore.dll and SQLiteExtension.dll. |
- | </div> | + | |
