map_suite_project_template_guide
map_suite_project_template_guide [2017/04/24 06:42]
tgwikiupdate
map_suite_project_template_guide [2017/04/26 20:16] (current)
mwolffer
Line 4: Line 4:
-This guide shows how to quickly create a simple project ​based on "ThinkGeo ​MapSuite ​online project ​template"​.+This guide shows how to quickly create a simple project ​using ThinkGeo's Map Suite online project ​templates.
-===== Detail ​Steps =====+===== Detailed ​Steps =====
-==== Install project template ​====+==== Installing Project Template ​====
-Open Visual Studio 2015 or 2017 and create a new project: "​File"​->"​New"​->"​Project", ​then select "​Online"​ and search keyword "​MapSuite"​.+Open Visual Studio 2015 or 2017 and create a new project: "​File"​->"​New"​->"​Project",​ select "​Online"​ and search keyword "​MapSuite"​.
 {{:​map_suite_project_template_guide_1.png|}} {{:​map_suite_project_template_guide_1.png|}}
-You should want to download a template ​and install ​it now, for example: "Map Suite Desktop for WinForms App Template"​.+Download ​and install ​a template, for example: "Map Suite Desktop for WinForms App Template"​.
 {{:​map_suite_project_template_guide_2.png|}} {{:​map_suite_project_template_guide_2.png|}}
-==== Create ​project ​with the installed template ​====+==== Create ​a Project ​with the Installed Template ​====
-Template is installedit start to download necessary package from NuGet automatic.+Once the template has been installed it will automatically ​download ​the necessary package(s) from NuGet.
 {{:​map_suite_project_template_guide_3.png|}} {{:​map_suite_project_template_guide_3.png|}}
-==== Build and run the default application ​====+==== Build and Run the Default Application ​====
-The first time you create a new project ​of one product, the "​product center" ​will popup+The first time you create a new project, the ThinkGeo Product Center ​will open
-If you don't have a license, ​it will automatic to start evaluation.+If you don't have a license, ​you will automatically ​start your free 60 day evaluation.
-If you have license ​for this product, you will be asked to activate your license. ​+If you have a licensed version ​for the product, you will be asked to activate your license. ​
 {{:​map_suite_project_template_guide_4.png|}} {{:​map_suite_project_template_guide_4.png|}}
Line 43: Line 43:
-After these steps, you had easily ​created and run template project.+After these steps, you can easily run the template project.
 {{:​map_suite_project_template_guide_6.png|}} {{:​map_suite_project_template_guide_6.png|}}
-You can write your code based on it now.+You can easily customize the template.
 {{:​map_suite_project_template_guide_7.png|}} {{:​map_suite_project_template_guide_7.png|}}
-==== Uninstall ​the project template ​====+==== Uninstalling ​the Project Template ​====
-Find the installed template in "​Extensions and Updates"​ under "​Tools"​ menu, click "​Uninstall" ​and you can remove ​it.+Find the installed template in "​Extensions and Updates"​ under "​Tools"​ menu, click "​Uninstall" ​to remove ​the project template.
 {{:​map_suite_project_template_guide_8.png|}} {{:​map_suite_project_template_guide_8.png|}}
map_suite_project_template_guide.1493016126.txt.gz · Last modified: 2017/04/24 06:42 by tgwikiupdate
