map_suite_faq_general_questions [2018/06/21 16:01] sacha created |
map_suite_faq_general_questions [2018/07/10 21:13] (current) sacha |
====== Map Suite Product FAQs and General Questions ====== | ====== Map Suite Product FAQs and General Questions ====== | ||
- | 1. What Products are offered in Map Suite 9.0 and 10.0? | + | ==== What Products are offered in Map Suite 9.0 and 10.0? ==== |
Map Suite 9.0 offers mapping component products for the following platforms: | Map Suite 9.0 offers mapping component products for the following platforms: | ||
- | **Mobile Platform** | + | **Mobile Platform** |
* Map Suite Android | * Map Suite Android | ||
* Map Suite IOS | * Map Suite IOS | ||
Line 25: | Line 27: | ||
* Map Suite Elevation | * Map Suite Elevation | ||
- | Map Suite 10 introduces the Map Suite Desktop, Web and Mobile Packages combining all individual components into one product. | + | Map Suite 10 introduces the Map Suite Desktop, Web and Mobile Packages combining all individual components into one product available for each platform. |
+ | ====What are the licensing options with ThinkGeo's Map Suite Products?==== | ||
+ | Map Suite 9.0 and 10.0 products offer both subscription and perpetual licensing options. | ||
+ | If developers are interested in purchasing mapping component licensing forever then our perpetual | ||
+ | licensing is the best route. Yearly software assurance renewal ensure year-round support and the ability | ||
+ | to upgrade to our latest versions when they are released. | ||
+ | Alternatively if a short project is all you need our components for then a subscription license | ||
+ | is the best fit. Year long subscriptions are available for the majority of our core Map Suite | ||
+ | products and specifically times subscriptions can be negotiated. | ||
+ | ====How does a user who has bought a Map Suite license access the Daily Builds available?==== | ||
+ | If you're using Map Suite 9.0 you will want to login to your ThinkGeo.com with your credential and access the community portal. Once there you'll find the Support tab. Within Support look for: | ||
+ | {{:dailybuilds.png?460|}} | ||
+ | Alternatively users on Map Suite 9.0 can access Daily Builds via their Product Center. | ||
+ | If a user is on Map Suite 10.0 Daily Builds are exclusively accessed through NuGet. | ||
+ | ====Where can I access Map Suite samples?==== | ||
+ | Every sample ThinkGeo has to offer is available on [[https://github.com/ThinkGeo]]; just download and run, and that's it. Even if you are new to ThinkGeo, no installer needs to be downloaded or installed to run the sample, in fact you don't even need to stop your debugging. If you're browsing our website samples are located one each web page of the respective product you're interested in as well as on our ThinkGeo Wiki. | ||
+ | ====What dependencies does Map Suite need on 9.0 vs 10.0?==== | ||
+ | By splitting MapSuiteCore 9.0 assemblies by functionality, it is easy to import necessary assemblies to projects. | ||
+ | Map Suite Products are hosted on NuGet servers instead of the Map Suite installer. | ||
+ | Movement of the required assemblies to a specific package makes it easier to deploy. | ||
+ | ________________________________________________________________________________________________________________________ | ||
+ | 9.0: unmanaged dependencies are in system32 folder. | ||
+ | 10.0: unmanaged dependencies are in the specific package. | ||
+ | With this switch from system32 to the bin folder of the project, it becomes much easier to deploy your project on the target machine(s) as there is no need to install to the registry. | ||
+ | ====What are the biggest feature differences in Map Suite 10.0 vs 9.0?==== | ||
+ | In the dialogue below we have some feedback regarding Map Suite 9.0 and how it is remedied in Map Suite 10.0 | ||
+ | |Map Suite 9.0 "Its only operational on Windows, I wish I could be developing on Linux as well. "| | ||
+ | |Map Suite 10.0 It now works on Linux/Mac through mono. You can develop the web server on Linux and Deploy it on Linux. You can get a better deal by just doing that.| | ||
+ | ||Map Suite 9.0 "The sample looks like what I need, but how do I make it run on my machine? I have to install this 170MB product center, sign up, activate the license, download the right version, change my reference in the sample……., that takes forever. "|| | ||
+ | ||Map Suite 10.0 Bump into a really good Map Suite Sample on GitHub? Just download and run, and that's it. Even if you are new to ThinkGeo, no installer needs to be downloaded or installed to run the sample, in fact you don't even need to stop your debugging. || | ||
+ | ||Map Suite 9.0 "The Daily Builds feature is awesome, but it's a bit overwhelming as it literally build daily even if there's no changes at all. Also I need to login to the portal, download that newer version and replace the assemblies in my project, too much work there, you know. "|| | ||
+ | ||Map Suite 10.0 A new Daily Build package is created only when changes are made. Want to keep the packages up to date? just click that single "Update" button in your NuGet Manager in Visual Studio and you are all set.|| | ||
+ | ||Map Suite 9.0 "The project works on my development machine but doesn't work on the server, and it turned out I have to install whole bunch of dependencies in System32 folder. "|| | ||
+ | ||Map Suite 10.0 The unmanaged dependencies are now in the bin folders as well. Just copy the bin folder to the new machine and it's good to go.|| | ||
+ | ||Map Suite 9.0 "Seems ThinkGeo fixed a bug in my Desktop Edition 2 months ago but it still exists in iOS/Android edition. "|| | ||
+ | ||Map Suite 10.0 The Core APIs and sources are shared across all Map Suite product lines. Once it's fixed in our Desktop Edition, it gets fixed automatically in iOS/Android Edition.|| | ||
+ | ====How do I upgrade from Map Suite 9.0 to Map Suite 10.0?==== | ||
+ | Since there are significant differences in the versions of Map Suite we offer an upgrade guide for everyone interested in updating to version 10. Please refer to the following guide for assistance: [[http://wiki.thinkgeo.com/wiki/map_suite_10_upgrade_guide ]] | ||
+ | ====How do I send a large "sample" or "test" file to ThinkGeo?==== | ||
+ | a. You can attach a test file to a community forum post or ticket both of which are accessible through our customer portal. | ||
+ | b. If you want to upload a large file you can email support@thinkgeo.com and we will open an account for you and send the credentials to you. | ||
+ | Once you receive the user credentials you can log in using the following options: | ||
+ | i. Through our Web Portal : Log in to https://clients.thinkgeo.com:5001/ with the credentials given to you and click on "File Station: on the Desktop; then click "Upload" and begin uploading. | ||
+ | ii. Through FTP (Using FileZilla for example) : | ||
+ | Go to File, Site Manager, and click the “New Site” Button | ||
+ | Name your new site and then enter the following information: | ||
+ | Host: clients.thinkgeo.com | ||
+ | Port: 21 | ||
+ | Protocol: FTP – File Transfer Protocol | ||
+ | Encryption: Require explicit FTP over TLS | ||
+ | Logontype: Normal | ||
+ | User: username (Use your credential instead) | ||
+ | Password: password (Use your password instead) | ||
+ | ====I installed the deployment license I bought but the "Not Licensed for Runtime" watermark still exists. How can you help?==== | ||
+ | - Uninstall your deployment server, and deactivate all the activated licenses if there’s any using your current version of product center. | ||
+ | - Clean up all the files within C:\ProgramData\ThinkGeo | ||
+ | - Update your product center to the latest version through Nuget | ||
+ | - Run the new product center and reinstall your deployment server | ||
+ | - If you still have the “Not licensed for Run Time” watermark, please make sure you’ve cleaned up the local cache and restart the web site. | ||
+ | ====How can I get general help from ThinkGeo?==== | ||
+ | For any tech questions, feel free to ask in our community([[http://community.thinkgeo.com/]] or use our ticketing system([[http://helpdesk.thinkgeo.com/TicketList]]), we have developers answering the questions there every day. Every customer has a limited number of tickets (5 per productmpurchase) and unlimited number of posts available to them in the community, of course our ticket system has higher priority. | ||
+ | If you want to have a consultation service other than that, we provide professional services which cost $150 an hour. It’s based on time and material and we bill weekly. | ||
