map_suite_core_10.2_features_bug_fixes_change_log
map_suite_core_10.2_features_bug_fixes_change_log [2017/11/01 03:35]
marklee
map_suite_core_10.2_features_bug_fixes_change_log [2017/11/06 05:03] (current)
tgwikiupdate
 ThinkGeo.MapSuite Namespace: ThinkGeo.MapSuite Namespace:
-  *Support ​online OSM building data with the ability to cache locally +  *Supported ​online OSM building data with the ability to cache locally
-  *Support ​3D rendering for buildings +  *Supported ​3D rendering for buildings
-  *Support ​USGS DEM data rendering with embedded styles +  *Supported ​USGS DEM data rendering with embedded styles
-  *Support ​more Interpolations (NearestNeighbor for example) for PlatformGeoCanvas +  *Supported ​more Interpolations (NearestNeighbor for example) for PlatformGeoCanvas
-  *Support ​KML projection from WGS84 to other projections +  *Supported ​KML projection from WGS84 to other projections
-  *Support ​different rendering orders (by Features or by ClassBreaks) for ClassBreakStyle +  *Supported ​different rendering orders (by Features or by ClassBreaks) for ClassBreakStyle
-  *Support ​different rendering orders (by Features or by ValueItems) for ValueStyle+  *Supported ​different rendering orders (by Features or by ValueItems) for ValueStyle
   *Added "​GetFeatureIds"​ API for all FeatureSources and FeatureLayers   *Added "​GetFeatureIds"​ API for all FeatureSources and FeatureLayers
-  *Upgrade ​FdoRasterRasterLayer&​FdoVectorFeatureLayer to use FDO 4.0+  *Upgraded ​FdoRasterRasterLayer&​FdoVectorFeatureLayer to use FDO 4.0
   *Fixed a bug where Proj4Projection.CanReproject returns incorrectly in some classes   *Fixed a bug where Proj4Projection.CanReproject returns incorrectly in some classes
   *Fixed a bug where "​ArgumentNullException"​ exception is thrown when GeoHatchBrush’s constructor is called in some scenarios   *Fixed a bug where "​ArgumentNullException"​ exception is thrown when GeoHatchBrush’s constructor is called in some scenarios
map_suite_core_10.2_features_bug_fixes_change_log.1509507321.txt.gz · Last modified: 2017/11/01 03:35 by marklee
