map_suite_core_10.2_features_bug_fixes_change_log
ThinkGeo.MapSuite Namespace:
  • Support online OSM building data with the ability to cache locally
  • Support 3D rendering for buildings
  • Support USGS DEM data rendering with embedded styles
  • Support more Interpolations (NearestNeighbor for example) for PlatformGeoCanvas
  • Support KML projection from WGS84 to other projections
  • Support different rendering orders (by Features or by ClassBreaks) for ClassBreakStyle
  • Support different rendering orders (by Features or by ValueItems) for ValueStyle
  • Upgrade FdoRasterRasterLayer&FdoVectorFeatureLayer to use FDO 4.0
map_suite_core_10.2_features_bug_fixes_change_log.1509507321.txt.gz · Last modified: 2017/11/01 03:35 by marklee
