map_suite_gps_tracking_server
Map Suite GPS Tracking Server
Map Suite GPS Tracking Server is web-based GPS tracking platform based on the core GIS components of Map Suite, which can be deployed anywhere to provide full-featured GPS tracking anywhere in the world. Customize the system easily via its modular tracking device support and robust developer APIs, or gain full control with the available source code option. Map Suite GPS Tracking Server is the ultimate solution for a developer-centric GPS tracking system.
User Guides
Guide Description
Web Portal Quick Start Guide
* Download PDF
* Download Word DOC
This illustrated, step-by-step guide covers working with the Map Suite GPS Tracking Server web portal, setting up GPS devices, working with departments and tracking your assets on the map.
Web Portal User Guide
* Read Online
* Download PDF
* Download Word DOC
Complete user guide for the Map Suite GPS Tracking Server web portal. Covers all aspects of the GPS tracking system's user interface, as well as the administration portal.
Tracking Device Connection Guide
This guide covers the requirements for connecting your tracking device to the Map Suite GPS Tracking Server.
Developer Guides
Guide Description
Device Gateway Overview Provides an overview of how GPS tracking devices communicate with the GPS Tracking Server's Device Gateway. It also provides details about the Gateway Web Services that allow you to integrate your own GPS tracking devices and custom functionality directly into the Map Suite GPS Tracking Server, using whichever programming language you prefer.
Web Services Reference Guide Full documentation of the methods available in the Map Suite GPS Tracking Server's portal web services. These services allow you to programmatically manage or retrieve information about your GPS tracking devices, departments, carriers, users, alerts and so forth.
Downloads and Resources
Resource Description
Supported GPS Tracking Devices A list of GPS tracking devices that we have certified for use with Map Suite GPS Tracking Server. If your device is not listed, you can write your own custom listener for it (or have us write one for you) using the Gateway SDK and Device Simulator tools.
Device Simulator The Device Simulator is a handy tool that lets you test the features of the GPS Tracking Server, simulate actual tracking conditions and create mock tracking sessions without ever leaving the comfort of your home or office.
Gateway SDK for .NET This API wrapper makes it easy for you to write your own custom device listeners against your Map Suite GPS Tracking Server's Device Gateway. It's the easiest way to add support for new or custom GPS tracking device hardware.
Sample Listeners We built these sample device listeners using the Gateway SDK for .NET to illustrate the process of developing your own custom device support. You can use any of these samples as a base when building your own custom listener for any device you wish.
Tracking Device Troubleshooting A guide on troubleshooting tracking device connection issues using the Debug Communications Log.
map_suite_gps_tracking_server.1441960609.txt.gz · Last modified: 2015/09/11 08:36 by admin
