vectortile:schema:v2:waterway
vectortile:schema:v2:waterway [2020/03/18 06:57]
tgwikiupdate
vectortile:schema:v2:waterway [2020/03/18 07:08] (current)
tgwikiupdate
Line 11: Line 11:
 ==== class ==== ==== class ====
-A category of waters, so that you can be easy to track a specific water object. The main field used for styling the marine is ''​class''​. The varying number represent different ​values.+A category of waters, so that you can easily ​track a specific water object. The possible ​values ​can be:
 ^Value ​            ​^Description^ ^Value ​            ​^Description^
-|''​ '​river'​ '' ​ |The linear flow of a riverin flow direction.| +|''​ '​river'​ '' ​ |A natural flowing watercourseusually freshwater, flowing towards an ocean, sea, lake or another river.|
-|''​ '​stream'​ ''​ |Very small waterway.| +|''​ '​stream'​ ''​ |Very small waterway, usually no wider than a meter or two.|
-|''​ '​canal'​ '' ​ |Artificial ​waterway.|+|''​ '​canal'​ '' ​ |An artificial ​waterway ​constructed for passage of boats or ships.|
 |''​ '​drain'​ '' ​ |Artificial channel for rainwater drainage, often concrete lined.| |''​ '​drain'​ '' ​ |Artificial channel for rainwater drainage, often concrete lined.|
 |''​ '​ditch'​ '' ​ |Small artificial channel dug in the ground for rainwater drainage.| |''​ '​ditch'​ '' ​ |Small artificial channel dug in the ground for rainwater drainage.|
-==== name field ==== +==== name ====
-^Field ​  ​^Description^ +The name of the river
-|''​name'' ​  |The name (or names) used locally for the place.+
-|''​name_en''​|English (if available, otherwise same as name)|+
 +==== name_en ====
 +The name of the river in English.
vectortile/schema/v2/waterway.1584514636.txt.gz · Last modified: 2020/03/18 06:57 by tgwikiupdate
