thinkgeo_web_for_api
ThinkGeo Web UI for WebAPI
Note: This page is for ThinkGeo UI WPF V12 and above, we highly suggest you to upgrade to this version if you are on an old one. Here is a quick guide how to do it: Updating to ThinkGeo 12. Version 12 supports both .NET Core and .NET Framework, the old versions support .NET Framework only.
ThinkGeo Web UI for WebAPI is a .NET Standard component using WebAPI, the cutting edge technology from Microsoft.
Getting Started
Helps you get you up to speed with integrating the ThinkGeo Web for WebAPI map control into your GIS software.
Product Guides
Introduces what licenses are needed / how the license would work for debugging/deploying the ThinkGeo products
Introduces the dependencies ThinkGeo Web for WebAPI needs with their features, versions and source websites.
Explains how to use styles in ThinkGeo to beautifully represent your GIS mapping data. The guide includes an overview of styles, a detailed explanation of the various styles that ship with ThinkGeo, as well as a step by step guide of creating your own custom styles.
Show ThinkGeo features coverage of different product and different platfoms
Code Samples
Browse the demo applications to see the power of ThinkGeo Web UI for WebAPI.
Samples
All samples about ThinkGeo Web UI for WebAPI.
Package
API Documentation
  • ThinkGeo.UI.WebAPI
    It covers the ThinkGeo.UI.WebAPI namespace which resides in the ThinkGeo.UI.WebAPI.dll assembly, including the map control itself, Overlays, and supported map classes. It also covers all the types in ThinkGeo.Core which is the key dependency of WebAPI.
Frequently Asked Questions
  • Do I have control over how the map looks and fits into my application
    Yes, absolutely. ThinkGeo Web for WebAPI is a control, so you can easily integrate it into your application just like any other control from the Toolbox. We expose a large amount of APIs that allow you to customize every aspect of the map and the user interface so that they fit in with the look and feel of your application.
  • What other software is required to work with ThinkGeo Web for WebAPI?
    Microsoft Visual Studio, or VS Code.
  • What type of map data does ThinkGeo Web for WebAPI Support?
    ThinkGeo Web for WebAPI comes with native support for the most popular vector and raster file formats, and includes a free extension that enables support for more than a dozen more vector formats and raster formats. Check out Data Formats Guide for detail.
  • How big of a learning curve is there to using ThinkGeo Web for WebAPI?
    ThinkGeo Web for WebAPI was designed to be easy to understand and easy to use. While mapping/GIS controls typically have a larger learning curve than other simpler controls like grids or charts, we feel ThinkGeo has taken the complexity out of mapping and allows you to develop your application in days or weeks instead of weeks or months.
  • Where do I go if I need help with ThinkGeo Web for WebAPI?
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
thinkgeo_web_for_api.1589921612.txt.gz · Last modified: 2020/05/19 20:53 by benbai
