thinkgeo_vector_map_javascript_library [2019/02/15 20:25] benbai [Product Guides] |
thinkgeo_vector_map_javascript_library [2019/04/29 15:44] sacha [Getting Started] |
Line 6: | Line 6: | ||
HTML5, WebGL Vector map JavaScript library with any vector data – EsriJSON, GML, GPX, GeoJSON, KML, Vector Tile (MVT), WFS, WKT or WMS, can be beautifully rendered with CSS similar style file – [[https://thinkgeo.gitbooks.io/map-suite-stylejson-specification/content/|StyleJSON]] schema. It’s an extension of [[https://openlayers.org/|OpenLayers]], and fits any requirements in browsers and mobile devices. | HTML5, WebGL Vector map JavaScript library with any vector data – EsriJSON, GML, GPX, GeoJSON, KML, Vector Tile (MVT), WFS, WKT or WMS, can be beautifully rendered with CSS similar style file – [[https://thinkgeo.gitbooks.io/map-suite-stylejson-specification/content/|StyleJSON]] schema. It’s an extension of [[https://openlayers.org/|OpenLayers]], and fits any requirements in browsers and mobile devices. | ||
- | With Map Suite VectorMap.js, you will have full access to [[https://openlayers.org/|OpenLayers]], as well as any plugins or extensions created based on [[https://openlayers.org/|OpenLayers]], for example, the "[[http://openlayers.org/3rd-party/|3rd party libraries]]" published on https://openlayers.org. With the help of them, you can easily create any styled map and put it anywhere, and build a customized geocoding or routings from other providers. | + | With Map Suite VectorMap.js, you will have full access to [[https://openlayers.org/|OpenLayers]] as well as any plugins or extensions created based on [[https://openlayers.org/|OpenLayers]]. For example, the "[[http://openlayers.org/3rd-party/|3rd party libraries]]" published on https://openlayers.org. With these samples you can easily create any styled map and put it anywhere. Additionally users can build a customized geocoding or routing apps from other providers. |
===== Getting Started ===== | ===== Getting Started ===== | ||
- | It's very easy to get started. You can start from getting the samples from GitHub, or start from creating a new application in your Visual Studio. | + | You can start building via ThinkGeo samples on GitHub or start by creating a new application in your Visual Studio. |
<div dokuteaser> | <div dokuteaser> |
