thinkgeo_stylejson [2020/01/09 06:44] johnnyz [StyleJSON Schema] |
thinkgeo_stylejson [2020/01/21 03:41] johnnyz [ThinkGeo StyleJSON Schema] |
Line 3: | Line 3: | ||
- | The ThinkGeo StyleJSON Schemai llustrated "GettingStarted" Guide will guide you through the process of studying what is ThinkGeo StylJSON Schema, and how to use it in your desktop, web, or mobile mapping applications. </div> | + | The ThinkGeo StyleJSON Schema illustrated "GettingStarted" Guide will guide you through the process of studying what is ThinkGeo StylJSON Schema, and how to use it in your desktop, web, or mobile mapping applications. </div> |
<markdown> | <markdown> | ||
- | StyleJSON is a describable [cartographic](https://en.wikipedia.org/wiki/Cartography) styling language in the [JSON](http://www.json.org/) format, which is similar to working with a Cascading Style Sheet for styling webpages. It defines the visual appearance of a map - what data should be drawn, the drawing sequence, and how to style the data when drawing it. Taking advantage of StyleJSON will allow you to add a great-looking map to your project in minutes, a browser, a phone, a tablet, or even a watch. | + | StyleJSON is a describable [cartographic](https://en.wikipedia.org/wiki/Cartography) styling language in the [JSON](http://www.json.org/) format, which is similar to working with a Cascading Style Sheet (CSS) for styling web-pages. It defines the visual appearance of a map - what data should be drawn, he order to draw it in, and how to style the data when drawing it. Taking advantage of StyleJSON will allow you to add a great-looking map to your project in minutes, a browser, a phone, a tablet, or even a watch. |
</markdown> | </markdown> | ||
+ | The intended audience of this specification includes: | ||
+ | * [[thinkgeo_stylejson#install_world_streets_styles|How to install the ThinkGeo "World Street Styles"]] | ||
+ | * [[thinkgeo_stylejson#stylejson_schema|"StyleJson" schema]] | ||
===== Install World Streets Styles ===== | ===== Install World Streets Styles ===== | ||
Line 19: | Line 23: | ||
<code JavaScript> | <code JavaScript> | ||
- | <--Light Style--> | + | <--Light Style--> |
- | <script src="https://cdn.thinkgeo.com/worldstreets-styles/1.0.0/light.json"></script> | + | <script src="https://cdn.thinkgeo.com/worldstreets-styles/4.0.0/light.json"></script> |
<--Dark Style--> | <--Dark Style--> | ||
- | <script src="https://cdn.thinkgeo.com/worldstreets-styles/1.0.0/dark.json"></script> | + | <script src="https://cdn.thinkgeo.com/worldstreets-styles/4.0.0/dark.json"></script> |
<--Transparent Background Style--> | <--Transparent Background Style--> | ||
- | <script src="https://cdn.thinkgeo.com/worldstreets-styles/1.0.0/transparent-background.json"></script> | + | <script src="https://cdn.thinkgeo.com/worldstreets-styles/4.0.0/transparent-background.json"></script> |
<--Cobalt Style--> | <--Cobalt Style--> | ||
- | <script src="https://cdn.thinkgeo.com/worldstreets-styles/1.0.0/cobalt.json"></script> | + | <script src="https://cdn.thinkgeo.com/worldstreets-styles/4.0.0/cobalt.json"></script> |
<--Grayscale Style--> | <--Grayscale Style--> | ||
- | <script src="https://cdn.thinkgeo.com/worldstreets-styles/1.0.0/grayscale.json"></script> | + | <script src="https://cdn.thinkgeo.com/worldstreets-styles/4.0.0/grayscale.json"></script> |
<--Muted Blue Style--> | <--Muted Blue Style--> | ||
- | <script src="https://cdn.thinkgeo.com/worldstreets-styles/1.0.0/mutedblue.json"></script> | + | <script src="https://cdn.thinkgeo.com/worldstreets-styles/4.0.0/mutedblue.json"></script> |
<--Sepia Style--> | <--Sepia Style--> | ||
- | <script src="https://cdn.thinkgeo.com/worldstreets-styles/1.0.0/oldancient.json"></script> | + | <script src="https://cdn.thinkgeo.com/worldstreets-styles/4.0.0/oldancient.json"></script> |
</code> | </code> | ||
Line 44: | Line 48: | ||
==== NPM ==== | ==== NPM ==== | ||
- | * Install the package: | + | Install the package: |
npm i worldstreets-styles | npm i worldstreets-styles | ||
===== StyleJSON Schema ===== | ===== StyleJSON Schema ===== | ||
- | [[version_1.0|Version 1.0]] | + | ==== History Versions ==== |
+ | [[Version 1.0.0|Version 1.0.0]] | ||
- | ==== Syntax ==== | + | ==== Version 2.0.0 ==== |
+ | ==== Root Properties==== | ||
Line 66: | Line 73: | ||
The following example map is created with styleJson. | The following example map is created with styleJson. | ||
- | [[https://maps.thinkgeo.com|{{stylejson-sample.png|StyleJSON Map}}]] | + | [[https://maps.thinkgeo.com|{{thinkgeo_stylejson:worldstreets_v2.png|StyleJSON Map}}]] |
- | * **styleJson object** | + | * **styleJson object**<div>A styleJson declaration format consists of the following elements: |
- | A styleJson declaration format consists of the following elements: | + | |
<code json> | <code json> | ||
Line 81: | Line 86: | ||
"styles": [...], | "styles": [...], | ||
"sources": [...], | "sources": [...], | ||
- | "layers": [...] | + | "map-layers": [...] |
- | + | </div> | |
- | * **version** | + | * **version**<div>//Required// `float` |
- | //Required// `float` | + | |
JSON Map CSS specification version number. | JSON Map CSS specification version number. | ||
- | + | </div> | |
- | * **owner** | + | * **owner**<div>//Optional// `string` |
- | //Optional// `string` | + | |
This JSON Map CSS belongs to someone, company or organization. | This JSON Map CSS belongs to someone, company or organization. | ||
- | * **time** | + | * **time**<div>//Optional// `string` |
This JSON Map CSS when to be created. | This JSON Map CSS when to be created. | ||
- | * background | + | * **background**<div>Set the map's background color. |
- | Set the map's background color. | + | * **variables**<div>//Optional// `object` |
- | * **variables** | + | |
- | //Optional// | + | |
All variables must be defined in this property and their name must begin with @. | All variables must be defined in this property and their name must begin with @. | ||
Line 122: | Line 120: | ||
- | * **styles** | + | </div> |
- | + | * **styles**<div>//Required// `array` | |
- | //Required// `array` | + | |
Define all map rendered styles. They include point, line, polygon, text etc. | Define all map rendered styles. They include point, line, polygon, text etc. | ||
- | * **sources** | + | * **sources**<div>//Optional// `array` |
- | //Required// `array` | + | Define all map data sources, |
- | Define all map data sources. | + | * **map-layers**<div>//Required// `array` |
- | * **layers** | + | Map styles and map data sources are linked by layers. Layers will be drawn in the order of array. |
- | //Required// `array` | ||
- | Map styles and map data sources are linked by layers. Layers will be drawn in the order of array. | + | **Hint**: The second chapter of this book has more information about styles, sources and layers. |
- | **Hint**: The second chapter of this book has more information about styles, sources and layers. | ||
==== Styles ==== | ==== Styles ==== | ||
- | "styles": [ | + | "styles": [ |
- | "id": "style1", | + | "id": "style1", |
- | "filter": "layerName='layer1'", | + | "filter": "layerName='layer1'", |
- | "z-index": "columnName" | + | "z-index-atrribute-name": "columnName" |
- | "style": [...] | + | "styles": [...] |
- | * **id** | + | * **id**<div>//Required// `string` |
- | //Required// `string` | + | |
A map rendered style's unique identifier. | A map rendered style's unique identifier. | ||
- | | + | </div> |
- | * **filter** | + | * **filter**<div>//Optional// `string` |
- | //Optional// `string` | + | Select some data which is need to render map.</div> |
- | Select some data which is need to render map. | + | * **z-index-atrribute-name**<div>//Optional// `string` |
- | * **z-index** | + | Map data would be sorted by this column's value.</div> |
- | //Optional// `string` | + | * **styles**<div>//Require// `array` |
- | Map data would be sorted by this column's value. | + | |
- | * **style** | + | |
- | //Require// `array` | + | |
Some specific map rendered styles. | Some specific map rendered styles. | ||
- | "style": [ | + | "styles": [ |
- | "filter": "zoom>=0;zoom<=19;highway='motorway'", | + | "filter": "zoom>=0;zoom<=19;highway='motorway'", |
- | "line-color": "#000", | + | "line-color": "#000", |
- | "line-width": 6, | + | "styles": [ |
- | "style": [ | + | { |
- | { | + | "filter": "type='monorail,subway'", |
- | "line-color": "#fff", | + | "line-width": 2 |
- | "line-width": 4, | + | }, |
- | "children": [ | + | { |
- | { | + | "filter": "type!='monorail,subway'", |
- | "line-color": "#000", | + | "line-width": 1 |
- | "line-width": 2 | + | } |
- | + | </div> | |
- | * **children** | + | |
- | //Optional// `array` | + | |
- | Children would use the same feature as the parent style, but it only uses styles by itself, it wouldn't use styles from it's parent. | + | |
=== Point === | === Point === | ||
- | * **point-dx** `number` | + | * **point-allow-overlapping** `boolean`<div> |
- | Description: //The horizontal offset of drawn graphic. It's available when the **point-type** is not symbol.// | + | //Allows overlap with other text or icons.// |
- | Default Value: `0` | + | Default Value: `flase` |
- | "point-dx": 3 | + | "point-allow-overlapping": false |
+ | * **point-fill-color** `string`<div> | ||
- | * **point-dy** `number` | + | //A defined fill color of symbol or glyph.// |
- | Description: //The vertical offset of drawn graphic. It's available when the **point-type** is not symbol.// | + | |
- | Default Value: `0` | + | |
- | "point-dy": 3 | + | "point-fill": "#fff" |
+ | * **point-glyph-content** `string`<div> | ||
- | * **point-file** `string` | + | //A defined glyph name that renders how a point appears.// |
- | Description: //A defined image path that renders how a point appears.// | + | |
- | "point-file": "http://www.image.com/image.png" | + | "point-glyph-content": "\ue001" |
- | * **point-fill** `string` | + | </div> |
+ | * **point-glyph-font-name** `string`<div> | ||
- | Description: //A defined fill of symbol or glyph.// | + | //A defined glyph type that renders how a point appears.// |
- | "point-fill": "#fff" | + | "point-glyph-font-name": "vectormap-icons" |
- | * **point-glyph** `string` | ||
- | Description: //A defined glyph type that renders how a point appears.// | + | * **point-mask-color** `string`<div> |
- | <code json> | + | //Sets the color of mask fill.// |
- | "point-glyph": "ThinkgeoFont" | + | |
- | </code> | + | |
- | * **point-glyph-mask-color** `string` | + | |
- | Description: //Sets the color of mask fill.// | + | |
- | "point-glyph-mask-color": "#000" | + | "point-mask-color": "#000" |
- | * **point-glyph-mask-margin** `string` | + | </div> |
+ | * **point-mask-margin** `string`<div> | ||
- | Description: //Sets the 4 distances of mask margin, in pixels.// | + | //Sets the 4 distances of mask margin, in pixels.// |
Default Value: `0,0,0,0` | Default Value: `0,0,0,0` | ||
- | "point-glyph-mask-margin": "1,1,1,1" | + | "point-mask-margin": "1,1,1,1" |
+ | * **point-mask-outline-color** `string`<div> | ||
- | * **point-glyph-mask-outline-color** `string` | + | //Sets the color of mask outline.// |
- | Description: //Sets the color of mask outline.// | + | |
- | "point-glyph-mask-outline-color": "#000" | + | "point-mask-outline-color": "#000" |
- | * **point-glyph-mask-outline-width** `number` | + | * **point-mask-outline-width** `number`<div> |
- | Description: //Sets the width of mask outline, in pixels.// | + | //Sets the width of mask outline, in pixels.// |
- | "point-glyph-mask-outline-width": 3 | + | "point-mask-outline-width": 3 |
+ | * **point-mask-type** `enum`<div> | ||
- | * **point-glyph-mask-type** `enum` | + | //Sets the type of text mask.// |
- | Description: //Sets the type of text mask.// | + | |
Available Values: `default` `rectangle` `roundedCorners` `roundedEnds` `circle` | Available Values: `default` `rectangle` `roundedCorners` `roundedEnds` `circle` | ||
- | "point-glyph-mask-type": "circle" | + | "point-mask-type": "circle" |
+ | * **point-offset-x** `number`<div> | ||
- | * **point-glyph-name** `string` | + | //The horizontal offset of drawn graphic. // |
- | + | Default Value: `0` | |
- | Description: //A defined glyph name that renders how a point appears.// | + | |
- | "point-glyph-name": "\ue001" | + | "point-offset-x": 3 |
+ | * **point-offset-y** `number`<div> | ||
- | * **point-linear-gradient** `string` | + | //The vertical offset of drawn graphic.// |
- | Description: //A defined glyph and symbol are rendered by the linear gradient.// | + | |
- | <code json> | + | |
- | "point-linear-gradient": "[0:#000],[1,#fff]" | + | |
- | </code> | + | |
- | * **point-outline-color** `string` | + | |
- | Description: //A defined outline color of symbol or glyph.// | + | |
- | "point-outline-color": "#000" | + | |
- | </code> | + | |
- | * **point-outline-width** `number` | + | |
- | Description: //A defined outline width of symbol or glyph.// | + | |
Default Value: `0` | Default Value: `0` | ||
- | "point-outline-width": 1 | + | "point-offset-y": 3 |
- | * **point-opacity** `number` | + | * **point-opacity** `number`<div> |
- | Description: //Sets the overall opacity of the point.// | + | //Sets the overall opacity of the point.// |
Default Value:`1`, //the point if fully opaque.// | Default Value:`1`, //the point if fully opaque.// | ||
Available Values: `0` to `1` | Available Values: `0` to `1` | ||
Line 334: | Line 299: | ||
"point-opacity": 1 | "point-opacity": 1 | ||
- | * **point-radial-gradient** `string` | + | * **point-outline-color** `string`<div> |
- | Description: //A defined glyph and symbol are rendered by the radial gradient.// | + | //A defined outline color of symbol or glyph.// |
- | "point-radial-gradient": "[0:#000],[1:#fff]" | + | "point-outline-color": "#000" |
- | * **point-rotate-angle** `number` | + | * **point-outline-width** `number`<div> |
- | Description: //A defined rotate angle that how a point appears.// | + | //A defined outline width of symbol or glyph.// |
- | "point-rotate-angle": 90 | + | "point-outline-width": 1 |
+ | * **point-rotation-angle** `number`<div> | ||
- | * **point-size** `number` | + | //A defined rotate angle that how a point appears.// |
+ | Default Value: `0` | ||
- | Description: //A defined size of symbol or glyph.// | + | <code json> |
+ | "point-rotation-angle": 90 | ||
+ | </code> | ||
+ | * **point-size** `number`<div> | ||
+ | //A defined size of symbol or glyph.// | ||
Default Value: `1` | Default Value: `1` | ||
Line 360: | Line 336: | ||
"point-size": 9 | "point-size": 9 | ||
- | * **point-symbol-type** `enum` | + | * **point-symbol-type** `enum`<div> |
- | Description: //The symbol type is shown at the point position when the **point-type** is symbol. The type include circle, square, triangle, cross and star.// | + | //The symbol type is shown at the point position when the **point-type** is symbol. The type include circle, square, triangle, cross and star.// |
Available Values: `circle` `square` `triangle` `cross` `star` | Available Values: `circle` `square` `triangle` `cross` `star` | ||
Line 369: | Line 347: | ||
"point-symbol-type": "square" | "point-symbol-type": "square" | ||
- | * **point-type** `enum` | ||
- | Description: //The graphic type is shown at the point position. The type include symbol, image and glyph. symbol is a defined graphic; image is a picture and the glyph a user-defined special character set that works with "point-glyph-name"// | + | * **point-type** `enum`<div> |
+ | //The graphic type is shown at the point position. The type include symbol, image and glyph. symbol is a defined graphic; image is a picture and the glyph a user-defined special character set that works with "point-glyph-name"// | ||
Available Values: `symbol` `image` `glyph` | Available Values: `symbol` `image` `glyph` | ||
Line 378: | Line 358: | ||
"point-type": "symbol" | "point-type": "symbol" | ||
- | + | </div> | |
- | * **point-transform** `string` | + | |
- | Description: //Defines SVG transformation functions to scale how points appear.// | + | |
- | Default Value: `none`, //geometry is not transformed.// | + | |
- | Available Values: `translate` `scale` `rotate` `skew` | + | |
- | "point-transform": "translate(10,20)" | + | |
- | </code> | + | |
=== Line === | === Line === | ||
- | * **line-cap** `enum` | + | * **line-cap** `enum`<div> |
- | Description: //The display of line endings.// | + | //The display of line endings.// |
Default Value: `round` | Default Value: `round` | ||
Available Values: `round` `butt` `square` | Available Values: `round` `butt` `square` | ||
Line 402: | Line 372: | ||
- | * **line-cap-inner** `enum` | + | </div> |
+ | * **line-color** `string`<div> | ||
- | Description: //The display of inner line endings.// | + | //The color of the drawn line.// |
- | Default Value: `round` | + | |
- | Available Values: `round` `butt` `square` | + | |
- | "line-cap-inner": "butt" | + | |
- | </code> | + | |
- | * **line-cap-center** `enum` | + | |
- | Description: //The display of center line endings.// | + | |
- | "line-cap-center": "butt" | + | |
- | </code> | + | |
- | * **line-color** `string` | + | |
- | Description: //The color of the drawn line.// | + | |
Default Value: `rgba(0,0,0,0)`, //(transparent)// | Default Value: `rgba(0,0,0,0)`, //(transparent)// | ||
Line 431: | Line 382: | ||
- | * **line-color-inner** `string` | + | </div> |
+ | * **line-dasharray** `string`<div> | ||
- | Description: //The color of the drawn inner line.// | + | //Use a pair of length values [a,b] to set dash patterns, where (a) is the dash length and (b) is the gap length. You can set more values to achieve more complex patterns.// |
- | Default Value: `rgba(0,0,0,0)`, //(transparent)// | + | |
- | "line-color-inner": "#000" | + | |
- | </code> | + | |
- | * **line-color-center** `string` | + | |
- | Description: //The color of the drawn center line.// | + | |
- | "line-color-center": "#000" | + | |
- | </code> | + | |
- | * **line-dasharray** `string` | + | |
- | Description: //Use a pair of length values [a,b] to set dash patterns, where (a) is the dash length and (b) is the gap length. You can set more values to achieve more complex patterns.// | + | |
Line 457: | Line 391: | ||
- | * **line-dasharray-inner** `string` | ||
- | Description: //Use a pair of length values [a,b] to set dash patterns, where (a) is the dash length and (b) is the gap length. You can set more values to achieve more complex patterns.// | ||
- | <code json> | ||
- | "line-dasharray-inner": "3,4,1,2" | ||
- | </code> | ||
- | * **line-dasharray-center** `string` | + | </div> |
+ | * **line-direction-image-size** `string`<div> | ||
- | Description: //Use a pair of length values [a,b] to set dash patterns, where (a) is the dash length and (b) is the gap length. You can set more values to achieve more complex patterns.// | + | //the size of line direction image.// |
- | "line-dasharray-center": "3,4,1,2" | + | "line-direction-image-size": "10,5" |
- | * **line-gamma** `boolean` | + | </div> |
+ | * **line-direction-image-uri** `string`<div> | ||
- | Description: //The level of antialiasing of a stroke line.// | + | //Which kind of iamge are used to display line direction.// |
- | Default Value: `1`, //(fully antialiased)// | + | |
- | Available Values: `1` `0` | + | |
- | "line-gamma": true | + | "line-direction-image-uri": "data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAKCAYAAAC9vt6cAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAABiSURBVChTpZKBCsAgCETPfqkPnPvA/CW3RoW1BcoeHCZ0R0rwUkrRW0drB6lVL7yGJFWFR4YphL6etYFb7XDO+awBU3wQju7gxf8RlgVtERF78THXQyIieGQY5kr4H1gzAFwo70RBYPf8BQAAAABJRU5ErkJggg==" |
- | * **line-geometry-transform** `string` | + | </div> |
+ | * **line-geometry-transform** `string`<div> | ||
- | Description: //Applies transformation functions to a geometry// | + | //Applies transformation functions to a geometry// |
Default Value: `none`, //(geometry is not transformed)// | Default Value: `none`, //(geometry is not transformed)// | ||
Available Values: `tranlate` `scale` `rotate` `skew` | Available Values: `tranlate` `scale` `rotate` `skew` | ||
Line 493: | Line 421: | ||
- | * **line-join** `enum` | + | </div> |
+ | * **line-join** `enum`<div> | ||
- | Description: //The behavior of lines when joined on a map.// | + | //The behavior of lines when joined on a map.// |
Default Value: `miter` | Default Value: `miter` | ||
Available Values: `miter` `round` `bevel` | Available Values: `miter` `round` `bevel` | ||
Line 503: | Line 432: | ||
- | * **line-join-inner** `enum` | + | </div> |
+ | * **line-miterlimit** `number`<div> | ||
- | Description: //The behavior of inner lines when joined on a map.// | + | //The limit on the ratio of the miter length to the stroke-width. This is used to automatically convert miter joins to bevel joins for sharp angles, to avoid the miter extending beyond the thickness of the stroking path. Typically, this property does not need to be set. However, if you have jaggy artifacts during rendering, defining a larger value for this property helps.// |
- | Default Value: `miter` | + | |
- | Available Values: `miter` `round` `bevel` | + | |
- | "line-join-inner": "miter" | + | |
- | </code> | + | |
- | * **line-join-center** `enum` | + | |
- | Description: //The behavior of center lines when joined on a map.// | + | |
- | "line-join-center": "miter" | + | |
- | </code> | + | |
- | * **line-miterlimit** `number` | + | |
- | Description: //The limit on the ratio of the miter length to the stroke-width. This is used to automatically convert miter joins to bevel joins for sharp angles, to avoid the miter extending beyond the thickness of the stroking path. Typically, this property does not need to be set. However, if you have jaggy artifacts during rendering, defining a larger value for this property helps.// | + | |
Defult Value: `4`, //(auto-convert miter joins to bevel joins when theta is less than 29 degrees)// | Defult Value: `4`, //(auto-convert miter joins to bevel joins when theta is less than 29 degrees)// | ||
Line 532: | Line 442: | ||
- | * **line-miterlimit-inner** `number` | + | </div> |
- | Description: //The limit on the ratio of the miter length to the stroke-width. This is used to automatically convert miter joins to bevel joins for sharp angles, to avoid the miter extending beyond the thickness of the stroking path. Typically, this property does not need to be set. However, if you have jaggy artifacts during rendering, defining a larger value for this property helps.// | + | * **line-offset-x** `number`<div> |
- | Defult Value: `4`, //(auto-convert miter joins to bevel joins when theta is less than 29 degrees)// | + | |
+ | //The horizontal offset of drawn line. // | ||
- | "line-miterlimit-inner": 4 | + | "line-offset-x": 3 |
- | * **line-miterlimit-center** `number` | + | </div> |
+ | * **line-offset-y** `number`<div> | ||
- | Description: //The limit on the ratio of the miter length to the stroke-width. This is used to automatically convert miter joins to bevel joins for sharp angles, to avoid the miter extending beyond the thickness of the stroking path. Typically, this property does not need to be set. However, if you have jaggy artifacts during rendering, defining a larger value for this property helps.// | + | //The vertical offset of drawn line.// |
- | Defult Value: `4`, //(auto-convert miter joins to bevel joins when theta is less than 29 degrees)// | + | Default Value: `0` |
- | "line-miterlimit-center": 4 | + | "line-offset-y": 3 |
- | * **line-oneway-symbol** `string` | + | </div> |
- | Description: //Which kind of symbol are used to display oneway tags.// | + | |
- | "line-oneway-symbol": "_icon.png" | + | |
- | </code> | + | |
- | * **line-opacity** `number` | + | * **line-opacity** `number`<div> |
- | Description: //The opacity of a line.// | + | //The opacity of a line.// |
Default Value: `0`, //(the line is fully transparent)// | Default Value: `0`, //(the line is fully transparent)// | ||
Line 568: | Line 475: | ||
- | * **line-width** `number` | ||
- | Description: //The width of a line, in pixels.// | + | </div> |
+ | * **line-width** `number`<div> | ||
+ | //The width of a line, in pixels.// | ||
Line 577: | Line 486: | ||
- | * **line-width-inner** `number` | + | </div> |
- | Description: //The width of a inner line, in pixels.// | + | |
- | Default Value: `1` | + | |
- | "line-width-inner": 1 | + | |
- | </code> | + | |
- | * **line-width-center** `number` | + | |
- | "line-width-center": 1 | + | |
- | </code> | + | |
=== Polygon === | === Polygon === | ||
- | * **polygon-brush-type** `enum` | + | * **polygon-fill-color** `string`<div> |
- | Description: //Choose which kind of brush type to render polygon shape.// | + | |
- | Default Value: `solid` | + | |
- | Available Value: `solid` `hatch` `radialgradient` `lineargradient` `texture` | + | |
- | "polygon-brush-type": "solid" | + | |
- | </code> | + | |
- | * **polygon-dx** `number` | + | |
- | Description: //The horizontal offset of drawn graphic.// | + | |
- | "polygon-dx": 3 | + | |
- | </code> | + | |
- | * **polygon-dy** `number` | + | |
- | Description: //The vertical offset of drawn graphic.// | + | |
- | "polygon-dy": 3 | + | |
- | </code> | + | |
- | * **polygon-fill** `string` | + | |
- | Description: //Sets the fill color of the polygon.// | + | //Sets the fill color of the polygon.// |
Default Value: `rgba(128,128,128,1)` //(completely opaque gray)// | Default Value: `rgba(128,128,128,1)` //(completely opaque gray)// | ||
- | "polygon-fill": "rgba(128,128,128,1)" | + | "polygon-fill-color": "rgba(128,128,128,1)" |
- | * **polygon-foreground-fill** `string` | + | </div> |
- | Description: //Sets the foreground fill of the polygon.// | + | * **polygon-geometry-transform** `string`<div> |
- | Default Value: `#000` | + | |
- | <code json> | + | //Defines the transform function for the geometry element.// |
- | "polygon-foreground-fill": "#000" | + | |
- | </code> | + | |
- | * **polygon-gamma** `boolean` | + | |
- | Description: //Sets the anti-aliasing level at the edge of the feature, affecting the rendering effect and speed.// | + | |
- | Default Value: `1`, //(Completely anti-aliasing)// | + | |
- | "polygon-gamma": true | + | |
- | </code> | + | |
- | * **polygon-geometry-transform** `string` | + | |
- | Description: //Defines the transform function for the geometry element.// | + | |
Available Values: `translate` `scale` `rotate` `skew` | Available Values: `translate` `scale` `rotate` `skew` | ||
Line 662: | Line 509: | ||
- | * **polygon-hatch-style** `enum` | + | </div> |
+ | * **polygon-offset-x** `number`<div> | ||
- | Description: //Choose which kind of hatch style pattern to render polygon shape.// | + | //The horizontal offset of drawn graphic.// |
- | Available Values: `cross` `horizontal` `vertical` `forwardDiagonal` `backwardDiagonal` `largegrid` `diagonalcross` `percent05` `percent10` `percent20` `percent25` `percent30` `percent40` `percent50` `percent60` `percent70` `percent75` `percent80` `percent90` | + | Default Value: `0` |
- | "polygon-hatch-style": "percent80" | + | "polygon-offset-x": 3 |
- | * **polygon-linear-gradient** `string` | + | </div> |
+ | * **polygon-offset-y** `number`<div> | ||
- | Description: //A defined polygon is rendered by the linear gradient.// | + | //The vertical offset of drawn graphic.// |
- | "polygon-linear-gradient": "[0:#000],[1:#fff]" | + | "polygon-offset-y": 3 |
- | * **polygon-opacity** `number` | ||
- | Description: //Control opacity factor of polygon color. (0 as completely transparent, 1 as completely opaque)// | + | </div> |
+ | * **polygon-opacity** `number`<div> | ||
+ | //Control opacity factor of polygon color. (0 as completely transparent, 1 as completely opaque)// | ||
Defult Value: `1` //(completely opaque)// | Defult Value: `1` //(completely opaque)// | ||
Line 689: | Line 541: | ||
- | * **polygon-outline-color** `string` | + | </div> |
+ | * **polygon-shadow** `object`<div> | ||
- | Description: //The color of the drawn polygon's outline.// | + | //The style of the drawn polygon's shadow.// |
- | "polygon-outline-color": "#000" | + | "polygon-shadow": { |
+ | "polygon-fill-color": "#90BBF5", | ||
+ | "polygon-offset-x": -1.5, | ||
+ | "polygon-offset-y": 1.5 | ||
- | * **polygon-outline-dasharray** `string` | + | </div> |
+ | === Text === | ||
- | Description: //Use a pair of length values [a,b] to set dash patterns, where (a) is the dash length and (b) is the gap length. You can set more values to achieve more complex patterns.// | + | * **text-align** `enum`<div> |
- | <code json> | + | //Sets the alignment of text.// |
- | "polygon-outline-dasharray": "[3,4,1,2]" | + | Default Value: `center` |
- | </code> | + | Available Values: `left` `right` `center` |
- | * **polygon-outline-opacity** `number` | + | |
- | Description: //Control opacity factor of polygon outline color. (0 as completely transparent, 1 as completely opaque)// | + | |
- | Default Value: `1` //(completely opaque)// | + | |
- | Available Values: `0` to `1` | + | |
- | "polygon-outline-opacity": 1 | + | "text-align": "left" |
- | * **polygon-outline-width** `number` | + | </div> |
+ | * **text-allow-overlapping** `boolean`<div> | ||
- | Description: //The width of a polygon outline, in pixels.// | + | //Allows overlap with other text or icons.// |
- | Default Value:`0` | + | Default Value: `flase` |
- | "polygon-outline-width": 1 | + | "text-allow-overlapping": false |
- | * **polygon-radial-gradient** `string` | + | </div> |
+ | * **text-baseline** `enum`<div> | ||
- | Description: //A defined polygon is rendered by the radial gradient.// | + | //Sets the current text baseline when the text is drawn.// |
+ | Default Value: `middle` | ||
+ | Available Values: `bottom` `top` `middle` `alphabetic` `hanging` `ideographic` | ||
- | "polygon-radial-gradient": "[0:#000],[1:#fff]" | + | "text-baseline": "top" |
- | * **polygon-shadow-color** `string` | + | </div> |
+ | * **text-base-point-style** `object`<div> | ||
- | Description: //The color of the drawn polygon's shadow.// | + | //a point style to display the base point.// |
- | "polygon-shadow-color": "#ccc" | + | "text-baseline": { |
+ | "point-type": "glyph", | ||
+ | "point-glyph-font-name": "vectormap-icons", | ||
+ | "point-outline-color": "@text_white_halo_color", | ||
+ | "point-outline-width": 1.5, | ||
+ | "point-glyph-content": "\ue0c0", | ||
+ | "point-fill-color": "@poi_color", | ||
+ | "point-size": 14, | ||
+ | "point-offset-y": -6 | ||
+ | * **text-content** `string`<div> | ||
- | * **polygon-shadow-dx** `number` | + | //Sets the text displayed on the text lable. You can specify the data field you want to use by using the field name enclosed in brackets, for example: {name_en}.// |
- | "polygon-shadow-dx": 3 | + | "text-content": "{name}" |
- | * **polygon-shadow-dy** `number` | + | </div> |
+ | * **text-date-format** `string`<div> | ||
- | Description: //The vertical offset of drawn graphic.// | + | //Sets a format expression for date value when the type of value is numeric.// |
- | "polygon-shadow-dy": 3 | + | "text-date-format": "yyyy-mm-dd" |
- | * **polygon-texture-file** `string` | + | </div> |
+ | * **text-fill-color** `string`<div> | ||
- | Description: //A defined image path that renders how a polygon appears.// | + | //Set the color of the text lable.// |
+ | Default Value: `#000000` //(black)// | ||
- | "polygon-texture-file": "http://www.image.com/image.png" | + | "text-fill-color": "argb(255,255,0,1)" |
- | === Text === | + | </div> |
- | * **text-align** `enum` | + | * **text-font** `string`<div> |
- | Description: //Sets the alignment of text.// | + | //Sets the current font property of the text content.// |
- | Default Value: `center` | + | |
- | Available Values: `left` `right` `center` | + | |
- | "text-align": "left" | + | "text-font": "600 12px Arial" |
- | * **text-baseline** `enum` | + | </div> |
+ | * **text-force-horizontal-for-line** `boolean`<div> | ||
- | Description: //Sets the current text baseline when the text is drawn.// | + | //Sets the force horizontal of the text for line.// |
- | Default Value: `middle` | + | |
- | Available Values: `bottom` `top` `middle` `alphabetic` `hanging` `ideographic` | + | |
- | "text-baseline": "top" | + | |
- | </code> | + | |
- | * **text-date-format** `string` | + | |
- | Description: //Sets a format expression for date value when the type of value is numeric.// | + | |
- | "text-date-format": "yyyy-mm-dd" | + | |
- | </code> | + | |
- | * **text-dx** `number` | + | |
- | Description: //Sets the horizontal offset of the text, in pixels. A positive value shifts the text to the right.// | + | |
+ | Available Values: `1` `0` | ||
- | "text-dx": 10 | + | "text-force-horizontal-for-line": 1 |
- | * **text-dy** `number` | + | </div> |
+ | * **text-halo-color** `string`<div> | ||
- | Description: //Sets the vertical offset of the text, in pixel. A positive value shifts the text down.// | + | //Sets the halo color on the text edge.// |
- | Default Value: `0` | + | Default Value: `#FFFFFF`, //(white)// |
- | "text-dy": 10 | + | "text-halo-color": "#000" |
- | * **text-font** `string` | + | </div> |
+ | * **text-halo-radius** `number`<div> | ||
- | Description: //Sets the current font property of the text content.// | + | //Sets the radius of the halo, in pixels.// |
+ | Default Value: `0`, //(no halo is applied)// | ||
- | "text-font": "600 12px Arial" | + | "text-halo-radius": 2 |
- | * **text-fill** `string` | + | </div> |
+ | * **text-interval-distance** `number`<div> | ||
- | Description: //Set the color of the text lable.// | + | //Sets the interval distancebetween text lables which along line.// |
- | Default Value: `#000000` //(black)// | + | |
- | "text-fill": "argb(255,255,0,1)" | + | "text-interval-distance": 1 |
- | * **text-force-horizontal-for-line** `boolean` | + | </div> |
+ | * **text-letter-case** `enum`<div> | ||
- | Description: //Sets the force horizontal of the text for line.// | + | //Sets the type of letter case.// |
- | Default Value: `0` | + | Default Value: `default` |
- | Available Values: `1` `0` | + | Availabel Values: `default` `uppercase` `lowercase` |
- | "text-force-horizontal-for-line": 1 | + | "text-letter-case": "uppercase" |
- | * **text-halo-fill** `string` | + | </div> |
+ | * **text-letter-spacing** `number`<div> | ||
- | Description: //Sets the halo color on the text edge.// | + | //Sets the width of letter spacing.// |
- | Default Value: `#FFFFFF`, //(white)// | + | |
- | "text-halo-fill": "#000" | + | "text-letter-spacing": 2 |
- | * **text-halo-radius** `number` | + | </div> |
+ | * **text-line-spacing** `number`<div> | ||
- | Description: //Sets the radius of the halo, in pixels.// | + | //Sets the width of line spacing.// |
- | Default Value: `0`, //(no halo is applied)// | + | |
- | "text-halo-radius": 2 | + | "text-line-spacing": 2 |
- | * **text-letter-case** `enum` | + | </div> |
+ | * **text-mask-color** `string`<div> | ||
- | Description: //Sets the type of letter case.// | + | //Sets the color of mask fill.// |
- | Default Value: `default` | + | |
- | Availabel Values: `default` `uppercase` `lowercase` | + | |
- | "text-letter-case": "uppercase" | + | |
- | </code> | + | |
- | * **text-mask-color** `string` | + | |
Line 876: | Line 720: | ||
- | * **text-mask-margin** `string` | + | </div> |
+ | * **text-mask-margin** `string`<div> | ||
- | Description: //Sets the 4 distance of mask margin, in pixels.// | + | //Sets the 4 distance of mask margin, in pixels.// |
Line 885: | Line 730: | ||
- | * **text-mask-outline-color** `string` | + | </div> |
+ | * **text-mask-outline-color** `string`<div> | ||
- | Description: //Sets the color of mask outline.// | + | //Sets the color of mask outline.// |
Line 893: | Line 739: | ||
- | * **text-mask-outline-width** `number` | + | </div> |
+ | * **text-mask-outline-width** `number`<div> | ||
Default Value:`0` | Default Value:`0` | ||
Line 902: | Line 749: | ||
- | * **text-mask-type** `enum` | + | </div> |
+ | * **text-mask-type** `enum`<div> | ||
- | Description: //Sets the type of text mask.// | + | //Sets the type of text mask.// |
Line 911: | Line 759: | ||
- | * **text-max-char-angle** `number` | + | </div> |
+ | * **text-max-char-angle-delta** `number`<div> | ||
- | Description: //For line feature, allow a maximum angle between adjacent characters, the expected value is in radians.// | + | //For line feature, allow a maximum angle between adjacent characters, the expected value is in radians.// |
Default Value: `2p` | Default Value: `2p` | ||
Available Values: `0` to `2p` | Available Values: `0` to `2p` | ||
- | "text-max-char-angle": 0.5 | + | "text-max-char-angle-delta": 0.5 |
- | * **text-min-distance** `number` | + | </div> |
+ | * **text-numeric-format** `string`<div> | ||
- | Description: //Sets the minimum distance between text lables.// | + | //Sets a numeric format expression for number value.// |
- | "text-min-distance": 1 | + | "text-numeric-format": "en-US, style: currency, currency: USD" |
+ | * **text-offset-x** `number`<div> | ||
- | * **text-min-padding** `number` | + | //Sets the horizontal offset of the text, in pixels. A positive value shifts the text to the right.// |
- | Description: //Sets the minimum margin for text lable in meta tiles.// | + | |
- | "text-min-padding": 3 | + | "text-offset-x": 10 |
+ | * **text-offset-y** `number`<div> | ||
- | * **text-name** `string` | + | //Sets the vertical offset of the text, in pixel. A positive value shifts the text down.// |
- | Description: //Sets the text displayed on the text lable. You can specify the data field you want to use by using the field name enclosed in brackets, for example: column_name.// | + | |
- | "text-name": "column_name" | + | "text-offset-y": 10 |
+ | * **text-opacity** `number`<div> | ||
- | * **text-numeric-format** `string` | + | //Set the opacity of text lable.// |
- | Description: //Sets a numeric format expression for number value.// | + | |
- | "text-numeric-format": "en-US, style: currency, currency: USD" | + | |
- | </code> | + | |
- | * **text-opacity** `number` | + | |
- | Description: //Set the opacity of text lable.// | + | |
Default Value: `1`, //(fully opaque)// | Default Value: `1`, //(fully opaque)// | ||
Line 962: | Line 806: | ||
"text-opacity": 1 | "text-opacity": 1 | ||
+ | * **text-placement** `string`<div> | ||
- | * **text-placement-type** `enum` | + | // you can use this property to set the avoidance algorithm for text lables.// |
- | + | Default Value: `center`, | |
- | Description: //Sets the algorithm for text lables to avoid each other. 'detect' means to use the basic algorithm specified by the text-placements property, 'default' means not to use this property.// | + | Available Values: `upper` `right` `lower` `left` `center` |
- | Available Values: `default` `detect` | + | |
- | "text-placement-type": "detect" | + | "text-placements": "upper" |
+ | * **text-rotate-angle** `number`<div> | ||
- | * **text-placements** `string` | + | //Rotation in radians (positive rotation clockwise).// |
- | Description: //If text-placement-type is set to 'detect', you can use this property to set the avoidance algorithm for text lables.// | + | |
- | Available Values: `U` `B` `L` `R` | + | |
- | "text-placements": "U" | + | |
- | </code> | + | |
- | * **text-rotate-angle** `number` | + | |
- | Description: //Rotation in radians (positive rotation clockwise).// | + | |
Available Values: `0` to `2*PI` | Available Values: `0` to `2*PI` | ||
Line 991: | Line 826: | ||
"text-rotate-angle": 2 | "text-rotate-angle": 2 | ||
+ | * **text-spacing** `number`<div> | ||
- | * **text-spacing** `number` | + | //Sets the space between two text lables drawn on a line, in pixels.// |
- | Description: //Sets the space between two text lables drawn on a line, in pixels.// | + | |
Line 1000: | Line 835: | ||
"text-spacing": 0 | "text-spacing": 0 | ||
+ | * **text-wrap-width** `number`<div> | ||
- | * **text-text-format** `string` | + | //The length of characters that appears before the text-name lable wraps.// |
- | Description: //Sets a format expression for text value.// | + | |
- | "text-text-format": "{0} test" | + | |
- | </code> | + | |
- | * **text-wrap-before** `boolean` | + | |
- | Description: //Controls the wraping action of text-name.// | + | |
- | Default Value: `false`, //(wrapped text appears longer than wrap-width )// | + | |
- | Available Values: `true` `false` | + | |
- | "text-wrap-before": true | + | |
- | </code> | + | |
- | * **text-wrap-width** `number` | + | |
- | Description: //The length of characters that appears before the text-name lable wraps.// | + | |
Line 1028: | Line 845: | ||
- | === Shield === | ||
- | * **shield-align** `enum` | + | </div> |
- | Description: //Sets the alignment of shield lable.// | + | |
- | Available Values: `left` `right` `center` `end` `start` | + | |
- | "shield-align": "left" | + | |
- | </code> | + | |
- | * **shield-date-format** `string` | + | |
- | Description: //Sets a format expression for date value.// | + | |
- | "shield-date-format": "yyyy-mm-dd" | + | |
- | </code> | + | |
- | * **shield-dx** `number` | + | |
- | Description: //Sets the horizontal offset of shield, in pixels. A positive value shifts the shield to the right.// | + | |
- | "shield-dx": 0 | + | |
- | </code> | + | |
- | * **shield-dy** `number` | + | |
- | Description: //Sets the vertical offset of shield, in pixels. A positive value shifts the shield down.// | + | |
- | "shield-dy": 0 | + | |
- | </code> | + | |
- | * **shield-face-name** `string` | + | |
- | Description: //Set the font and style of the marked text on the shield.// | + | |
- | "shield-face-name": "600 24px Verdana" | + | |
- | </code> | + | |
- | * **shield-fill** `string` | + | |
- | Description: //Sets the color of the text of the shield.// | + | |
- | "shield-fill": "#000" | + | |
- | </code> | + | |
- | * **shield-font** `string` | + | |
- | Description: //Sets the current font property of the shield content.// | + | |
- | "shield-font": "600 12px Arial" | + | |
- | </code> | + | |
- | * **shield-halo-fill** `string` | + | |
- | Description: //Sets the color of the shield text.// | + | |
- | Default Value: `#FFF`, //(white)// | + | |
- | "shield-halo-fill": "#000" | + | |
- | </code> | + | |
- | * **shield-halo-radius** `number` | + | |
- | Description: //Sets the radius of shield text, in pixels.// | + | |
- | Default Value: `0`, //(shield text without halo)// | + | |
- | "shield-halo-radius": 0 | + | |
- | </code> | + | |
- | * **shield-icon-color** `string` | + | |
- | Description: //Sets the color of icon when the //`shield-icon-type`// is //`symbol`//.// | + | |
- | "shield-icon-color": "#fff" | + | |
- | </code> | + | |
- | * **shield-icon-outline-color** `string` | + | |
- | Description: //Sets the outline color of icon when the //`shield-icon-type`// is //`symbol`//.// | + | |
- | "shield-icon-outline-color": "#fff" | + | |
- | </code> | + | |
- | * **shield-icon-outline-width** `number` | + | |
- | Description: //Sets the outline width of icon when the //`shield-icon-type`// is //`symbol`//.// | + | |
- | "shield-icon-outline-width": 3 | + | |
- | </code> | + | |
- | * **shield-icon-size** `number` | + | |
- | Description: //Sets the size of icon, in pixels.// | + | |
- | "shield-icon-size": 24 | + | |
- | </code> | + | |
- | * **shield-icon-src** `string` | + | |
- | Description: //Sets the source path of icon when the //`shield-icon-type`// is //`image`//.// | + | |
- | "shield-icon-src": "https://www.iconfinder.com/icons/1608409/download/svg/24" | + | |
- | </code> | + | |
- | * **shield-icon-symbol-type** `enum` | + | |
- | Description: _Sets symbol type of icon when the `shield-icon-type` is `symbol`. | + | |
- | Available Values: `circle` `square` `triangle` `cross` `star` | + | |
- | "shield-icon-symbol-type": "circle" | + | |
- | </code> | + | |
- | * **shield-icon-type** `enum` | + | |
- | Description: //Sets type of icon.// | + | |
- | Available Values: `image` `symbol` | + | |
- | "shield-icon-type": "symbol" | + | |
- | </code> | + | |
- | * **shield-name** `string` | + | |
- | Description: //Sets a name of column to display it's fields.// | + | |
- | "shield-name": "name" | + | |
- | </code> | + | |
- | * **shield-min-distance** `number` | + | |
- | Description: //Sets the minimum distance between adjacent two shield symbols (which can be the same shield or can be different).// | + | |
- | "shield-min-distance": 3 | + | |
- | </code> | + | |
- | * **shield-min-padding** `number` | + | |
- | Description: //Sets the minimum margin when the shield is marked on the tile.// | + | |
- | "shield-min-padding": 3 | + | |
- | </code> | + | |
- | * **shield-numeric-format** `string` | + | |
- | "shield-numeric-format": "en-US, style: currency, currency: USD" | + | |
- | </code> | + | |
- | * **shield-opacity** `number` | + | |
- | Description: //Sets the opacity of the 'shiled-file' image.// | + | |
- | Defult Value: `1` | + | |
- | Available Values: `0` //to// `1` | + | |
- | "shield-opacity": 1 | + | |
- | </code> | + | |
- | * **shield-orientation** `number` | + | |
- | Available Values: `0` //to// `2p` | + | |
- | "shield-orientation": 1 | + | |
- | </code> | + | |
- | * **shield-placement-type** `enum` | + | |
- | Description: //Sets the algorithm for shields to avoid each other. //`detect`// means to use the basic algorithm specified by the shield-placements property, //`default`// means not to use this property.// | + | |
- | "shield-placement-type": "detect" | + | |
- | </code> | + | |
- | * **shield-placements** `string` | + | |
- | Description: //If shield-placement-type is set to //`detect`//, you can use this property to set the avoidance algorithm for shield.// | + | |
- | "shield-placements": "U" | + | |
- | </code> | + | |
- | * **shield-rotate-angle** `number` | + | |
- | Available Values: `0` to `2p` | + | |
- | "shield-rotate-angle": 2 | + | |
- | </code> | + | |
- | * **shield-spacing** `number` | + | |
- | Description: //Sets the interval distance between the shields.// | + | |
- | "shield-spacing": 3 | + | |
- | </code> | + | |
- | * **shield-text-format** `string` | + | |
- | "shield-text-format": "{0} test" | + | |
- | </code> | + | |
- | * **shield-wrap-width** `number` | + | |
- | Description: //Set how long the shield text needs to be folded.// | + | |
- | "shield-wrap-width": 0 | + | |
- | </code> | + | |
- | * **shield-wrap-before** `boolean` | + | |
- | Description: //Control the shield of the text of the folding action. If the value is false, then each line of text will be slightly longer than the value set by the wrap-width property.// | + | |
- | Available Values: `0` `1` | + | |
- | "shield-wrap-before": 0 | + | |
- | </code> | + | |
==== Sources ==== | ==== Sources ==== | ||
- | "sources": [ | + | "sources": [ |
- | "id": "worldstreets_source", | + | "id": "worldstreets_source", |
- | "url": "http://{ip address}/{vector tile file path}/{z}/{x}/{y}.mvt", | + | "url": "http://{ip address}/{vector tile file path}/{z}/{x}/{y}.mvt", |
- | "type": "MVT" | + | "type": "MVT" |
- | === id === | + | * ** id **<div>//Required// `string` |
A map rendered data source's unique identifier. | A map rendered data source's unique identifier. | ||
- | === url === | + | * ** url **<div>//Required// `string` |
The address of the data requested from the server. | The address of the data requested from the server. | ||
- | === type === | + | * ** type **<div>//Required// `string` |
The commonly used geospatial file formats of feature source,for example : JSONFeature, MVT, TextFeature and XMLFeature. But it only support "MVT" now. | The commonly used geospatial file formats of feature source,for example : JSONFeature, MVT, TextFeature and XMLFeature. But it only support "MVT" now. | ||
- | ==== Layers ==== | + | </div> |
+ | ==== map-layers ==== | ||
- | "layers": [ | + | "map-layers": [ |
- | "id": "layer1", | + | "map-layer-id": "worldstreets", |
- | "source": "source1", | + | "source":"sourceId" |
- | "styles": [ | + | "style-drawing-order": [ |
- | "style1" | + | "landcover_urban", |
- | === id === | + | * **map-layer-id **<div> |
//Required// `string` | //Required// `string` | ||
A layer's unique identifier. | A layer's unique identifier. | ||
- | === source === | + | * **source **<div> |
- | //Required// `string` | + | //Optional// `string` |
- | A source's unique identifier which has existed of sources. | + | A source's unique identifier which has existed of sources. Or it is passed in by JavaScript code with class ol.thinkgeo.VectorTileSource. |
- | === styles === | + | </div> |
+ | * **style-drawing-order **<div> | ||
//Required// `array` | //Required// `array` | ||
Some of map rendered styles' unique identifier. Styles will be drawn in the order of array. | Some of map rendered styles' unique identifier. Styles will be drawn in the order of array. | ||
