thinkgeo_runtime_license_guide_for_desktop [2019/09/18 15:17] benbai removed |
thinkgeo_runtime_license_guide_for_desktop [2020/05/19 20:43] benbai created |
- | ====== ThinkGeo UI for WPF Runtime Deployment Guide ====== | + | ====== ThinkGeo UI Desktop Runtime Deployment Guide ====== |
- | If you need to publish a desktop application that was developed with ThinkGeo UI for WPF components, it's required to publish your application along with the Runtime License. Otherwise, a map will be rendered with "Not Licensed for Run Time". This guide demonstrate how to setup the runtime license. | + | If you need to publish a desktop application that was developed with ThinkGeo UI Desktop components, it's required to publish your application along with the Runtime License. Otherwise, a map will be rendered with "Not Licensed for Run Time". This guide demonstrate how to setup the runtime license. |
===== Get Runtime License ===== | ===== Get Runtime License ===== | ||
- | A Runtime License can be generated by “ThinkGeo Product Center” which can be found from your application's bin folder (The same folder of the compiled *.exe file). Please double click ThinkGeo.MapSuite.ProductCenter.exe and switch to ThinkGeo UI Desktop for WPF tab as indicated in the figure below. | + | A Runtime License can be generated by “ThinkGeo Product Center” which can be found from your application's bin folder (The same folder of the compiled *.exe file). Please double click ThinkGeo.MapSuite.ProductCenter.exe and switch to ThinkGeo UI Desktop tab as indicated in the figure below. |
{{ ::mapsuite_product_center_winforms.png?direct |}} | {{ ::mapsuite_product_center_winforms.png?direct |}} |
