thinkgeo_mobile_for_android [2020/05/19 20:14] benbai |
thinkgeo_mobile_for_android [2020/09/15 21:25] kday [Code Samples] |
Line 2: | Line 2: | ||
- | **Note:** This page is for ThinkGeo UI Android V12 and above, we highly suggest you to upgrade to this version if you are on an old one. Here is a quick guide how to do it: [[thinkgeo_12_upgrade_guide|Updating to ThinkGeo 12]]. Version 12 supports both .NET Core and .NET Framework, the old versions support .NET Framework only. Here are the wikis for the old version: [[https://wiki.thinkgeo.com/wiki/map_suite_winforms_mobile_edition|Version 10 Android]] and [[https://wiki.thinkgeo.com/wiki/map_suite_winforms_mobile_edition| Version 9 Android]]. | + | **Note:** This page is for ThinkGeo UI Android V12 and above, we highly suggest you to upgrade to this version if you are on an old one. Here is a quick guide how to do it: [[thinkgeo_12_upgrade_guide|Updating to ThinkGeo 12]]. Version 12 supports both .NET Core and .NET Framework, the old versions support .NET Framework only. |
Line 17: | Line 17: | ||
- | >[[ThinkGeo Mobile for Android Installation Guide|Installation]] | + | > [[thinkgeo_license_guide_for_mobile|License]] |
- | Walks you through installing the ThinkGeo UI control on your system and creating a simple GIS application. | + | |
- | </div> | + | |
- | <div dokuteaser> | + | |
- | > [[thinkgeo_license_guide#thinkgeo_mobile_winforms|License]] | + | |
Introduces what licenses are needed and how licensing works for debugging and deploying projects using ThinkGeo UI. | Introduces what licenses are needed and how licensing works for debugging and deploying projects using ThinkGeo UI. | ||
Line 29: | Line 24: | ||
>[[thinkgeo_dependencies|Dependencies]] | >[[thinkgeo_dependencies|Dependencies]] | ||
- | Introduces the dependencies required by ThinkGeo Mobile for Android, along with their features, versions and source websites. | + | Introduces the dependencies required by ThinkGeo Mobile for iOS, along with their features, versions and source websites. |
- | <div dokuteaser> | ||
- | >[[thinkgeo_runtime_license_guide_for_winforms|Deployment]] | ||
- | Walks you through deploying your ThinkGeo UI project to your user base. | ||
- | </div> | ||
Line 45: | Line 34: | ||
> [[thinkgeo_12_upgrade_guide|Upgrading]] | > [[thinkgeo_12_upgrade_guide|Upgrading]] | ||
- | Describes how to upgrade to ThinkGeo UI 12 from previous versions of ThinkGeo UI or ThinkGeo Map Suite. | + | Describes how to upgrade to ThinkGeo UI 12 from previous versions of ThinkGeo UI. |
Line 64: | Line 53: | ||
- | ** All the samples are available on NuGet via the link below. ** | + | ** All the samples are available on GitLab via the link below. ** |
- | <faicon fa fa-navicon fa-lg> [[thinkgeo_mobile_for_winforms_all_samples|Samples]] | + | <faicon fa fa-navicon fa-lg> [[https://gitlab.com/thinkgeo/public/thinkgeo-mobile-maps/-/tree/master/samples/xamarin-forms|Samples]] |
