thinkgeo_cloud_client_keys_guideline [2019/02/06 21:46] benbai [Use a ThinkGeo Cloud Client Key] |
thinkgeo_cloud_client_keys_guideline [2019/02/15 17:22] benbai |
- | =====ThinkGeo Cloud Client Keys Guidline ===== | + | =====ThinkGeo Cloud Client Keys Guideline ===== |
A ThinkGeo Cloud Client Key is how you can enable your application or website to use ThinkGeo Cloud resources on your behalf. You can have as many client keys in your account as you like. Different application or website can use different keys or share the same one. | A ThinkGeo Cloud Client Key is how you can enable your application or website to use ThinkGeo Cloud resources on your behalf. You can have as many client keys in your account as you like. Different application or website can use different keys or share the same one. | ||
Line 11: | Line 11: | ||
Then, visit the ThinkGeo Cloud web console login page at https://cloud.thinkgeo.com/login.html and click the "Login with ThinkGeo Account" button. | Then, visit the ThinkGeo Cloud web console login page at https://cloud.thinkgeo.com/login.html and click the "Login with ThinkGeo Account" button. | ||
- | [[https://cloud.thinkgeo.com/login.html|{{:thinkgeo_cloud_login_page.png?nolink&500}}]] | + | [[https://cloud.thinkgeo.com/login.html|{{:thinkgeo_cloud_login_page.png?nolink}}]] |
Once logged in, click on the "Clients" button on the menu bar. | Once logged in, click on the "Clients" button on the menu bar. | ||
- | {{::thinkgeo_cloud_dashboard.png}} | + | {{::thinkgeo_cloud_dashboard.png?nolink}} |
New ThinkGeo Cloud accounts come with two clients, one is NativeConfidential and the other is JavaScript, which you can use to quickly get started. Click on the green **Show Keys** button and the ClientId & Client Secret (for NativeConfidential Key) or JavaScript API Key (for JavaScript Client Key) will show up and ready to use. Hit the blue pencil button on the far right to modify it. | New ThinkGeo Cloud accounts come with two clients, one is NativeConfidential and the other is JavaScript, which you can use to quickly get started. Click on the green **Show Keys** button and the ClientId & Client Secret (for NativeConfidential Key) or JavaScript API Key (for JavaScript Client Key) will show up and ready to use. Hit the blue pencil button on the far right to modify it. | ||
- | {{::thinkgeo_cloud_clientlist.png}} | + | {{::thinkgeo_cloud_clientlist.png?nolink}} |
====NativeConfidential and JavasScript Client Keys==== | ====NativeConfidential and JavasScript Client Keys==== | ||
Line 88: | Line 88: | ||
Click on "Add Client" button and here pops up the "Create Client" window as follows: | Click on "Add Client" button and here pops up the "Create Client" window as follows: | ||
- | {{::thinkgeo_cloud_create_client_javascript.png?nolink&500|}} | + | {{::thinkgeo_cloud_create_client_javascript.png?nolink|}} |
* **Name**: The name of this client, to be easily recognized. | * **Name**: The name of this client, to be easily recognized. | ||
Line 123: | Line 123: | ||
Log in to [[https://cloud.thinkgeo.com/help/|ThinkGeo Cloud Test Page]] and click on the green Authorize button. | Log in to [[https://cloud.thinkgeo.com/help/|ThinkGeo Cloud Test Page]] and click on the green Authorize button. | ||
- | {{::thinkgeo_cloud_api_test_page.png?400}} | + | {{::thinkgeo_cloud_api_test_page.png?nolink}} |
Available Authorizations window shows up and you can then input either a NativeConfidential(Client ID and Client Secret combination) or a JavaScript Key, and click the "Authorize" button to finish authorization. | Available Authorizations window shows up and you can then input either a NativeConfidential(Client ID and Client Secret combination) or a JavaScript Key, and click the "Authorize" button to finish authorization. | ||
- | {{::thinkgeo_cloud_available_authorizations_native_confidential.png?400}} | ||
All the APIs on [[https://cloud.thinkgeo.com/help/|ThinkGeo Cloud Test Page]] will be available to run online now after hitting the "Try it out" below each API. | All the APIs on [[https://cloud.thinkgeo.com/help/|ThinkGeo Cloud Test Page]] will be available to run online now after hitting the "Try it out" below each API. |
