<!– Enumeration –> This enumeration provides some options when querying a feature.
Three options are provided in the query system that can cover all possible cases. Option 1 is to use the ReturningColumnsType.NoColumns, which will return no columns at all. Option 2 is to use the ReturningColumnsType.AllColumns, which will return all columns. Option 3 is used when you want to return parts of the columns in the feature; in this case you should pass in an (IEnumerablestring returningColumnNames) instead of using this enumeration directly.
Name | Summary |
NoColumns | Return no column option. |
AllColumns | Return all columns option. |
