<!– Structure –>
*System.ValueType **ThinkGeo.MapSuite.WindowsPhoneCore.Cell
Cell | Int64, Int64, RectangleShape |
Equals | Object | Object(overriden) | This method is an override of the Equals functionality. |
GetHashCode | Object(overriden) | This method is an override of the GetHashCode functionality. | |
ToString | Object(overriden) | This method is an override of the ToString functionality. |
BoundingBox | RectangleShape | ||
Column | Int64 | ||
Index | Int64 | ||
Row | Int64 |
Name | Type | Description |
row | Int64<!– System.Int64 –> | |
column | Int64<!– System.Int64 –> | |
boundingBox | RectangleShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.RectangleShape –> |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Return Type |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Cell –> Go Back
Return Type |
Return Type |
Return Type |
