<!– Class –> This class is use for tiled WMS Server, and you also can get map from ThinkGeo world map kit server.
![]() | This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually. | ||
![]() | IEnumerable<Uri> | ||
![]() | IEnumerable<Uri>, GeoWebProxy | ||
![]() | IEnumerable<Uri>, String, String | ||
![]() | IEnumerable<Uri>, GeoWebProxy, String, String |
![]() | This method clears the tile cache of client. | ||
![]() | Layer | Create a copy of Layer using the deep clone process. | |
![]() | Layer | This method closes the Layer and releases any resources it was using. | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer | This method draws the Layer. |
![]() | Object | Object | |
![]() | Layer | This method returns the bounding box of the Layer. | |
![]() | ScreenPointF, String, Int32 | ||
![]() | ScreenPointF, String | ||
![]() | ScreenPointF | ||
![]() | ScreenPointF, Int32 | ||
![]() | Object | ||
![]() | RectangleShape, Int32, Int32 | Get the request URLs from the client to the WMS servers. | |
![]() | This API gets the GetCapabilites document of the service. | ||
![]() | This method returns the projected or geographic coordinate reference systems to be used. | ||
![]() | This method returns the exception format at the server side. | ||
![]() | This API gets the WMS server FeatureInfo formats of the service. | ||
![]() | This method returns the names of all layers at the server side. | ||
![]() | This method returns the output format at the server side. | ||
![]() | This method returns the names of all styles at the server side. | ||
![]() | This API gets the WMS server version of the service. | ||
![]() | Object | ||
![]() | Layer | This method opens the Layer so that it is initialized and ready to use. | |
![]() | RectangleShape, TimeSpan | Layer | |
![]() | IEnumerable<RectangleShape>, TimeSpan | Layer | |
![]() | IEnumerable<RectangleShape> | Layer | |
![]() | RectangleShape | Layer | |
![]() | Layer | ||
![]() | TimeSpan | Layer | |
![]() | Object |
![]() | Layer | Create a copy of Layer using the deep clone process. The default implemenation uses serialization. | |
![]() | Layer(overriden) | This method closes the Layer and releases any resources it was using. | |
![]() | GeoCanvas, String | Layer | |
![]() | GeoCanvas, Collection<SimpleCandidate> | Layer(overriden) | This method draws the Layer. |
![]() | GeoCanvas, Exception | Layer | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | GeoCanvas, Exception | Layer(overriden) | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
![]() | Object | ||
![]() | Object | ||
![]() | DrawingAttributionLayerEventArgs | Layer | |
![]() | DrawingExceptionLayerEventArgs | Layer | |
![]() | DrawingProgressChangedEventArgs | Layer | |
![]() | DrawnAttributionLayerEventArgs | Layer | |
![]() | DrawnExceptionLayerEventArgs | Layer | |
![]() | RequestedDrawingLayerEventArgs | Layer | |
![]() | RequestingDrawingLayerEventArgs | Layer | |
![]() | SendingWebRequestEventArgs | ||
![]() | SentWebRequestEventArgs | ||
![]() | Layer(overriden) | This method opens the Layer so that it is initialized and ready to use. |
![]() | Collection<String> | This property represents the available layers that can be requested from the client and shown on the map. | |
![]() | Collection<String> | This property represents the available styles that can be requested from the client and shown on the map. | |
![]() | String | Layer | |
![]() | WmsAxisOrder | ||
![]() | TimeSpan | ||
![]() | String | Gets or sets a value that is your Client Id. | |
![]() | ICredentials | This property gets or sets the base authentication interface for retrieving credentials for Web Client authentication. | |
![]() | String | This property gets or sets the projected or geographic coordinate reference system to be used. | |
![]() | DrawingExceptionMode | Layer | Gets or sets the DrawExcpetionMode when exception happens. |
![]() | TimeSpan | Layer | This property gets the last drawing time for the layer. |
![]() | String | This property indicates the format in which the client wishes to be notified of service exceptions. | |
![]() | Boolean | Layer(overriden) | This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. |
![]() | TiledWmsRasterSource | ||
![]() | Boolean | Layer | This property gets and sets if the image should be converted to grayscale. |
![]() | Boolean | Layer | This property gets and sets whether the image should be converted to negative (inverse colors). |
![]() | Boolean | Layer | This property returns true if the Layer is open and false if it is not. |
![]() | Boolean | Layer | This property gets and set the visible state of the layer. |
![]() | Double | Gets or sets a value represents lower threshold for scale. | |
![]() | String | Layer | This property gets and sets the name for the layer. |
![]() | String | This property gets or sets the desired output format for the map requested from the WMS. | |
![]() | Dictionary<String,String> | This property specifies a dictionary used to update the request sent from the client to the WMS server. | |
![]() | String | Gets or sets a value that is unique to your client ID, please keep your key secure. | |
![]() | Uri | Gets or sets a server uri of Tiled WMS Server. | |
![]() | Collection<Uri> | ||
![]() | BitmapTileCache | Gets or sets a BitmapTileCache represents which tile cache will be used. | |
![]() | Int32 | Gets or sets the height of the tile requested | |
![]() | Int32 | Gets or sets the width of the tile requested | |
![]() | Int32 | This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds. | |
![]() | Single | Layer | This property gets and sets the amount of transparency to apply to the image. |
![]() | Double | Gets or sets a value represents upper threshold for scale. | |
![]() | GeoWebProxy | This property gets or sets the proxy used for requesting a Web Response. | |
![]() | ZoomLevelSet |
![]() | Boolean | Layer(overriden) | This property returns true if the Layer is open and false if it is not. |
Name | Type | Description |
serverUris | IEnumerable<Uri><!– System.Collections.Generic.IEnumerable{System.Uri} –> |
serverUris | IEnumerable<Uri><!– System.Collections.Generic.IEnumerable{System.Uri} –> | |
webProxy | GeoWebProxy<!– ThinkGeo.MapSuite.PortableCore.GeoWebProxy –> |
clientId | String<!– System.String –> | |
privateKey | String<!– System.String –> |
webProxy | GeoWebProxy<!– ThinkGeo.MapSuite.PortableCore.GeoWebProxy –> | |
Return Type | Description |
Void<!– System.Void –> |
<!– ThinkGeo.MapSuite.PortableCore.TiledWmsLayer –> Go Back
Layer<!– ThinkGeo.MapSuite.PortableCore.Layer –> | A cloned Layer. |
<!– ThinkGeo.MapSuite.PortableCore.Layer –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | This parameter is the canvas object or a GeoImage to draw on. |
labelsInAllLayers | Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.SimpleCandidate} –> | This parameter represents the labels used for collision detection and duplication checking. |
RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | This method returns the bounding box of the Layer. |
Dictionary<String,Collection<Feature»<!– System.Collections.Generic.Dictionary{System.String,System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.PortableCore.Feature}} –> |
screenPointF | ScreenPointF<!– ThinkGeo.MapSuite.PortableCore.ScreenPointF –> | |
infoFormat | String<!– System.String –> | |
maxFeatures | Int32<!– System.Int32 –> |
Collection<Uri><!– System.Collections.ObjectModel.Collection{System.Uri} –> | The request URLs from the client to the WMS servers. |
requestExtent | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | The world extent requested by the client to get the map. |
canvasWidth | Int32<!– System.Int32 –> | The returning map width, as well as the drawing canvas width. |
canvasHeight | Int32<!– System.Int32 –> | The returning map height, as well as the drawing canvas height. |
String<!– System.String –> | This API returns the GetCapabilites document of the service. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | The exception format at the server side. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This API returns the FeatureInfo formats supported on the server-side. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns the names of all layers at the server side. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns the output format at the server side. |
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> | This method returns the names of all styles at the server side. |
String<!– System.String –> | Returns a string reflecting the version of the service in WMS. |
Type<!– System.Type –> |
extentToRefresh | RectangleShape<!– ThinkGeo.MapSuite.PortableCore.RectangleShape –> | |
bufferTime | TimeSpan<!– System.TimeSpan –> |
extentsToRefresh | IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.PortableCore.RectangleShape} –> | |
<!– ThinkGeo.MapSuite.PortableCore.Layer(overriden) –> Go Back
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | |
attribution | String<!– System.String –> |
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
canvas | GeoCanvas<!– ThinkGeo.MapSuite.PortableCore.GeoCanvas –> | The target canvas to draw the layer. |
e | Exception<!– System.Exception –> | The exception thrown when layer.Draw(). |
args | DrawingAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingAttributionLayerEventArgs –> |
e | DrawingExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionLayerEventArgs –> |
e | DrawingProgressChangedEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawingProgressChangedEventArgs –> |
args | DrawnAttributionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnAttributionLayerEventArgs –> |
e | DrawnExceptionLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.DrawnExceptionLayerEventArgs –> |
eventArgs | RequestedDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestedDrawingLayerEventArgs –> |
eventArgs | RequestingDrawingLayerEventArgs<!– ThinkGeo.MapSuite.PortableCore.RequestingDrawingLayerEventArgs –> |
e | SendingWebRequestEventArgs<!– ThinkGeo.MapSuite.PortableCore.SendingWebRequestEventArgs –> |
e | SentWebRequestEventArgs<!– ThinkGeo.MapSuite.PortableCore.SentWebRequestEventArgs –> |
This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer.
When requesting a map, a client may specify the layers to be shown on the map.
Return Type |
When requesting a map, a client may specify the styles to be shown on the map.
Return Type |
Return Type |
Return Type |
WmsAxisOrder<!– ThinkGeo.MapSuite.PortableCore.WmsAxisOrder –> |
Return Type |
Return Type |
Return Type |
ICredentials<!– System.Net.ICredentials –> |
Return Type |
Return Type |
DrawingExceptionMode<!– ThinkGeo.MapSuite.PortableCore.DrawingExceptionMode –> |
Return Type |
Upon receiving a request that is invalid according to the OGC standard, the server shall issue a service exception report. The service report is meant to describe to the client application or its human user the reason(s) that the request is invalid.
Return Type |
The value of TileWmsLayer is false.
Return Type |
Return Type |
TiledWmsRasterSource<!– ThinkGeo.MapSuite.PortableCore.TiledWmsRasterSource –> |
Return Type |
Return Type |
Return Type |
Return Type |
Is the current scale is less than this value, the map will not render.
Return Type |
Double<!– System.Double –> |
Return Type |
When requesting a map, a client may specify the output format in which to show the map. Format are specified as MIME types such as “image/gif” or “image/png”.
Return Type |
Return Type |
Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
Return Type |
Return Type |
Return Type |
Uri<!– System.Uri –> |
Return Type |
Return Type |
BitmapTileCache<!– ThinkGeo.MapSuite.PortableCore.BitmapTileCache –> |
Return Type |
Return Type |
Return Type |
Return Type |
Single<!– System.Single –> |
Is the current scale is beyond this value, the map will not render.
Return Type |
Return Type |
Return Type |
ZoomLevelSet<!– ThinkGeo.MapSuite.PortableCore.ZoomLevelSet –> |
Return Type |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
